Crash at startup with V9.4.1 - works with older versions [fixed]
DJL
Post by DJL »
Dear QuickDMX users and support,
I’ve been a long-time user of QuickDMX software and have gained a lot of knowledge here in the forum and experience through working with it over the years.
Currently, I’m encountering a serious issue with one of my shows. The project was rebuilt recently, and I suspect it may have been edited across multiple software versions unintentionally. The initial work started in version 9.4.0, then continued in 9.4.1, and some parts were edited on a different machine running version 9.3.8.
From the 9.3.8 environment, I exported the show and then imported it into 9.4.1. Since then, every attempt to open the show in 9.4.1 causes the application to crash immediately.
To rule out system-specific issues, I tested the same show file on another PC with a clean installation of QuickDMX. The result was the same: the show crashes in 9.4.1 but loads and runs correctly in 9.4.0.
This behavior suggests a potential compatibility issue or bug in version 9.4.1 when handling projects created or edited across mixed versions. Could someone from the development team assist in identifying the root cause? I'd also be happy to provide the show file if needed for debugging purposes.
Best regards,
Ludo
Re: Crashing sofware with one showfile at startup in 9.4.1 - works with older versions
Yes send us a zip of your lightshow (https://forum.thelightingcontroller.com ... c.php?t=19).
And we will check that.
DJL
Post by DJL »
Shows are send by e-mail.
Big thanks in advance
Ludo
Thank you for the lightshow.
We are able to reproduce the problem and we fixed it.
We need now some time for the software publishing procedures.
We will come back to you asap when ready.
DJL
Post by DJL »
Ok ! Happy with that :)
There is a new software version (9.4.3) (for Windows only) on line which fixes this problem.
https://forum.thelightingcontroller.com ... php?t=8415
DJL
Re: Crash at startup with V9.4.1 - works with older versions [fixed]
Post by DJL »
The new version is working for me!
Many thanks!
