Sweetlight 512 Interface Not Seen By Software [fixed]
usb to dmx (2009 - 2019)
cvbailey9
Post by cvbailey9 »
Hi, I have two versions of software running on two different PCs. I just upgraded to the latest version of software on one machine and the power light is lit on the 512 not the PC Link. The Software shows 0 interfaces connected. The unit continues to work fine on the older version. Any ideas? Thanks
[S/N:.........]
Gilles
Re: Sweetlight 512 Interface Not Seen By Software
Post by Gilles »
Vous avez installé le divershttps://thelightingcontroller.com/viewt ... f=2&t=5789
Quand vous dites 2 versions, se sont les mêmes version (V9)?
cvbailey9
Post by cvbailey9 »
That's brilliant. Thanks for your time. :-)
cvbailey9
Re: Sweetlight 512 Interface Not Seen By Software [fixed]
Post by cvbailey9 »
Hi, Driver updated and software sees 1 interface on loading but I still can't get a signal. PC Link light isn't on.
Gilles
Post by Gilles »
Salut, voilà ma procédure sous vindows 10:
Dans Gestionnaire périphérique
Cliquer sur suivant
Voici ensuite ce que vous aurez, et chez moi ça fonctionne.
Si je veux revenir à la version 2017, même chose mais je restaure l'ancien pilote.
cvbailey9
Post by cvbailey9 »
Thanks Giles, followed your instructions. Still not getting PC Link led on 512. Software sees the interface.
Unit is working on different PC with older version.
Regards
Colin
[image]
Return to “D512”
