My rig runs about 14 Par 64's, a 6spot, ColorPix, some Flat Pars, Hurricane 4D, some 4 color Lasers and 10-10Wrgbw Mini LED motion spots. The only lights on the DMX chain to not receive a DMX signal. There are 4 Pars in the DMX chain before these lights that receive a signal, uninterrupted and work just fine as do the other lights and lasers within the chain. Its not the profile created, yes the dmx is selected, no its not the high end DMX cables I use all have been tested, no there isn't any loose connections, yes all lights are MODED to 13 Channel and are properly functioning....all 10 DO NOT RECEIVE a signal but every other light does. Yes Ive put the light on a dmx cable by itself and still no signal so its not a weakened signal due to DMX length
Need to know if this software has this same issue with other lighting as I have searched a lot of the forums and haven't seen a fix or even a post stating that some lights are working and others are not. Thanks
