Hello
With other lightcontrollers (for example pulsar masterpiece) it is possible to configure multible scene steps if one base bpm signal triggers the scene. I use this for example for strobing a strobe, shutter or also LED pars. If one base bpm signal is detected, then multible fast strobe flashes are possible.
Can you tell me how I configure this in sweetlight software.
multible scene steps for auto bpm
Re: multible scene steps for auto bpm
Actually you can... set the velocity of the scene to AUTO BPM.. so... every step of you scene will be triggered by the BPM
or if you're doing a DJ show and you need "x" scene in 120bpm... then 130... then 140... you can use manual BPM for do the adjusment, and PROGRAMMING the scene would be like:
every step must last 1 second... so you have now a 120bpm scene... configure this in LIVE to AUTO-BPM or MANUAL-BPM... set the BPM... done!!!
