multible scene steps for auto bpm
bedo1976
Post by bedo1976 »
Hello
With other lightcontrollers (for example pulsar masterpiece) it is possible to configure multible scene steps if one base bpm signal triggers the scene. I use this for example for strobing a strobe, shutter or also LED pars. If one base bpm signal is detected, then multible fast strobe flashes are possible.
Can you tell me how I configure this in sweetlight software.
zkflow
Re: multible scene steps for auto bpm
Post by zkflow »
Actually you can... set the velocity of the scene to AUTO BPM.. so... every step of you scene will be triggered by the BPM
or if you're doing a DJ show and you need "x" scene in 120bpm... then 130... then 140... you can use manual BPM for do the adjusment, and PROGRAMMING the scene would be like:
every step must last 1 second... so you have now a 120bpm scene... configure this in LIVE to AUTO-BPM or MANUAL-BPM... set the BPM... done!!!
Return to “Live - Buttons”
