I tried a couple of tweaks and was satisfied with the results. This solutions I am proposing here is for advanced programmers with a good understanding of how button priorities work, and how to manipulate them to your advantage.
-LED Master Dimmer.
The earliest LEDs I used I set in simple mode and avoided the dimmer all together. Now I commonly use LEDs typically with all the channels possible. However I am still disinclined to use the master fader very often, preferring to programme the RGBAW faders individually. As such I prefer my Dimmer channel to be fully up at all times. So I have programmed a Master Dimmer button that is triggered by calendar, and I set the trigger to be the clock at 24/7. Now the Master Dimmer button is on all the time.
But BEWARE:
If you update Macros with the button on, that button will be incorporated into the Macros. To solve this I don't trigger the Dimmer Master Button until my last minute pre show prep. And if I make any Macro saves mid-show? I can delete my Master Dimmer button before my post show save.
Personally? I actually have 3 Master Dimmer Buttons loaded. So during a show if I compromise a 24/7 triggered Master Dimmer Button? I just delete it, and trigger the next Master Dimmer Button as 24/7.
If you ha e any questions, don't hesitate to ask me.
Master Dimmer Button for LEDs
ashley.saylor@facebook.com
http://projectpinkband.com/
http://johnnywadband.com
Re: Master Dimmer Button for LEDs
Nice workaround Pink, one I used successfully this past weekend.
Yeah, kinda a pain if you are changing macros on the fly...
TimE
TimE
Yes it is a pain. That is why I have redundant buttons loaded. Then if I change Macros on the fly I just delete the triggered button and re-trigger one of the redundant buttons.
But I don't really busk this show. This show is 50 to 80 shows a year with generally the same set list, so I can have most of the entire show pre-programmed. I am just hitting a few Macros a song.
