This is not a problem.
You just have to set the correct addresses in Pixels.
In Pixels, if the first fixture has the DMX address 148, the next one has to have the DMX address 148 + 50 = 198.
Chauvet Freedom Stick (50ch) - problem of strobe [fixed]
Re: pixel effects with the chauvet freedom stick x4 set?
See the pictures . I think i did it correct.
I can't find why the pixel are only work with strobe when i turn pixel on
- Schermafbeelding 2024-10-14 192501.png (64.07 KiB) Viewed 126112 times
- Schermafbeelding 2024-10-14 192448.png (63.89 KiB) Viewed 126112 times
- Schermafbeelding 2024-10-14 192549.png (63.17 KiB) Viewed 126112 times
Please check that the channel #49 "shutter" is not forced to the level "strobe".
section "Gedeelde kanalen" > button "Bewerken".
You can double check that in the window "DMX bargraph".
I think it use only RGB channels like the screenshot.
Shutter is 100% and Dimmer also 100% . I not use it by live control or editor. Only pixel control
- Schermafbeelding 2024-10-15 194711.png (1.28 KiB) Viewed 126069 times
- Schermafbeelding 2024-10-15 194443.png (80.91 KiB) Viewed 126069 times
shutter 100% gives fast strobeShutter is 100% and Dimmer also 100%
Oké! Thanks !
I have to turn off the fader. I though it was a slide fader for rgb channel .
