3D Generator Not Working - Please Help! [fixed]
monabaker
Post by monabaker »
I installed ShowXpress on my laptop without an issue EXCEPT the 3d generator doesn’t work. I have attached a screen shot. Any thoughts?
Re: 3D Generator Not Working - Please Help!
You can send us your lightshow.
We will check it.
monabaker
Post by monabaker »
How do I do this?
Pink LD
Post by Pink LD »
From the FAQ section of the Forum:
When and how to contact support
Postby support » 27 December 2009, 16:09
When necessary, we will ask you to send us some attachement by email.
Our email address is support"at"thelightingcontroller.com (replace "at" by @).
In order that everybody benefit of your message, first thing to do is to make a post in the forum.
We will answer exclusively to emails and private messages intended by us.
Send your files to the email address. I have done it myself before and they figured out my problem and fixed it. Good luck, I hope this helps!
monabaker
Post by monabaker »
What files do they want me to send to them? Just the screen shot I posted here? If so, I e-mailed that address last night and provided a link to this thread.
DoubleDee
Post by DoubleDee »
Email them your Lightshows file.
On my computer it's in the Harddrive/Documents and Settings/Administrator/TheLightingController.
I've sent them files as well. Most helpful.
monabaker
Post by monabaker »
E-mailed .ZIP file as instructed.
monabaker
Post by monabaker »
Okay, we're getting closer!
3D view is now working, and I can see the room, walls, ceiling, etc. I can move the room around just fine.
I cannot see any of my fixtures in it.
Suggestions?
monabaker
Post by monabaker »
PROBLEMS SOLVED!
No one from support got back to me (as of yet at least), but I was able to resolve the issue myself. It looked like 3D generator was trying to pull info from the previous version of ShowXpress. I uninstalled V5, and then reinstalled V6 which brought back the working generator, but then my fixtures didn't load. I went back into setup, went into the 1st fixture, changed a setting, changed it back, clicked save, and then all my stuff showed up!
At this point, I am good to go!
We received your zip file last night at 01:15, and (normally) during night period we do not work a lot.
Anyway, we are also able to see the fixtures of your lightshow, in 3DView.
We do not understand how there could be any conflict between V5 and V6, but the most important is your problem is fixed.
Return to “3DView”
