Beta? [fixed]
Re: Beta? [fixed]
it works fine on my sweetlight interface , but i must do all the dmx pathing for dmx out again?
Re: Beta? [fixed]
Please can you clarify what you mean by this?dj_calle wrote:but i must do all the dmx pathing for dmx out again?
Re: Beta? [fixed]
what does "force level in editor"
mean in the setup window?
Re: Beta? [fixed]
tomrbland:
i mean the patching so i can change colors and stuffs on a dmx wing, that didnt follow with the auto converter
also i think it is bad that it is less to chosse frome in the patch area if the software och wing should go first:(
Re: Beta? [fixed]
The patching part of the software has had a major overhaul. It is now much more efficient and easier for new users to understand. Plus you can do soft-patch channels. Much has changed since V5, it might be a good idea to take some time to discover the new features. Such as "forced fixed levels" as an example. Putting your phrase in to the search brought this up: "Setup - force faders in Editor to output only existing levels" useful for some specific fixtures that have reset channels for example. Ie where you need to get to an exact value quickly and accurately (lamp on/off etc). It means that you can only output the values assigned to that channel, not the in between ones (ie if lamp off=27 and lamp on=37 then you wont be able to set the channel to 30 if the force fixed levels is selected.)
Re: Beta? [fixed]
A full change-log is available here: viewtopic.php?f=9&t=8&p=8
Re: Beta? [fixed]
Yes i think i have every change under control know but iam still waiting on a good explenation why i cant use my pc brain interface, it is the same interface as everyone else, its just a matter of programing or the license file i think!
Re: Beta? [fixed]
With that matter, I'm afraid that I can't help. I only own the BOX interface.
Re: Beta? [fixed]
thanks anyway, youre really kind to take your time, hope for answear from support
