Hihi
How can i make nice pixel effects with the chauvet freedom stick x4 set?
There are 16 leds in the led tube. 1 led have 3 dmx channels for the color. How it works? Is it possible to add in the live buttons also?
I have 4 led tubes
Like to read!
Chauvet Freedom Stick (50ch) - problem of strobe [fixed]
Re: pixel effects with the chauvet freedom stick x4 set?
Here is the Pixels profile for it (48 channels).
You have to declare 4 units in Pixels with there correct DMX address, and then you could apply some color Fx on them.
Yes, it is possible to add a "Pixels scene" buttons in the section "Live buttons".
- ChauvetDJ_FreedomStick(48ch).pxl
- (294 Bytes) Downloaded 896 times
Thanks! I go try!!
Hi I did try
Nice pixel profile. Great!
Question: I have 48 channels : chanel 148 Red 149 Green 150 Blue ..... ... 195 blue.
If i check pixel profile it is more dmx channels.
One freedom stick begin by adress 148 and end by 195 dmx adress. 48 ch
How it works?
How it works?
- Schermafbeelding 2024-10-08 162141.png (45.53 KiB) Viewed 105369 times
Press "Start" to re-address all the LEDs.
I make it.
It works. Only the freedom sticks with stroboscoop light pixels. Why is it?
Like to read
I make it.
Like to read
Sorry we do not understand the question.
If i make a pixel pattern by pixel tab then the pixel leds are working. only the problem is the leds are stroboscoop. Not 100 % on but blinking stroboscoop
- Schermafbeelding 2024-10-13 105427.png (30.88 KiB) Viewed 105182 times
Please confirm that your Chauvet Freedom Stick are in mode "48 channels" and not "50 channels".
If yes, please post a video showing the strobe problem.
Hi
I saw also a pixel profile freedom stick 50 ch. I use this for pixel effects . Freedom stick 50 channel configured.
I like also to use the dimmer and strobe with scène screator.
By pixel editor use the pixel not the dimmer and strobe but the freedom stick make the pixel effect but in strobe effect.
I dont know what to do
