Hi, I can't get the QTX haze 3 to adjust the haze output. It's either full fan or nothing. Could you please tell me what it should be? Thanks
https://www.avsl.com/assets/manuals/1/6/160459UK.pdf
QTX - Haze 3
Re: QTX Haze 3
The manual you've posted just has
Channel 1 Fan (0-100%)
Channel 2 Haze output (0-100%)
That seems to be the only info provided. Hypothetically if you just put the fader at 50%, the fan should go at 50% speed, there's nothing more complicated than that.
Do you have a fixture profile you can use?
If the fader is at 50% and the fan is still running at max, sounds like it's an issue on the hazer rather than in the software
Re: QTX - Haze 3
Hi, Thanks for the reply, What seems to happen is having a fader set at 6% or less is nothing but 7% up is full on. I don't mind that if i could figure out which profile icon would make the flow change. I've tried lots but none seem to make the flow change.
Re: QTX - Haze 3
The icon won't make any difference. The hazer doesn't see anything more than a DMX value between 0 and 255. You could have it be something completely off like a colour wheel channel, it still would behave the same. The icon is just for your referenceav-shack wrote:Hi, Thanks for the reply, What seems to happen is having a fader set at 6% or less is nothing but 7% up is full on. I don't mind that if i could figure out which profile icon would make the flow change. I've tried lots but none seem to make the flow change.
Re: QTX - Haze 3
Oh I see. Yes of course
. Thank you for the replies.
