Midicon2 - how to change page ?
Urs
Post by Urs »
Dear Forum Members
I have the Elaton Midicon2 in use, together with ShowXpress. I would like to use the fader pages on the Midicon to use more than 8 faders. How can I configure this? Can I do it directly in ShowXpress or do I need the Midi Mapper software? Unfortunately it did not work with the learning button. The page is ignored.
Luc Henrion
Re: Midicon2 and ShowXpress
Post by Luc Henrion »
Looking at the Elation manual, it doesn't seem that the fader pages send a MIDI message... This is an issue you should submit to Elation.
Urs
Post by Urs »
According to Elation the whole fader bank should get a new midi address when changing the page. I will now check the firmware.
Our software is able to return a midi message only after receiving one.
Sorry for that.
Urs
Post by Urs »
The problem is solved.
With the Midi Mapper software from ADJ Midicon the paping can be enabled. After that process everything works fine.
Regards
Urs
Good news !
Thank you for the explanation.
