Light4Me - Bros 5 Beam
Svenino
Post by Svenino »
Could You please do the Profile for Light4Me - Bros Beam?
It´s a 5 movingheads bar and the 60 Chanel Mode would be necessary.
First part of PDF is polish, second english and copyable text:
https://www.musicexpress.pl/downloadabl ... /id/13313/
For infos around the item and german dmx-list:
https://www.prolighting.de/lichttechnik ... heads.html
Thank You in andvance
Best regards
Sven
Re: Light4Me - Bros 5 Beam
The profile is done.
Svenino
Post by Svenino »
Hallo, thank You for the fixture.
Problem1: In 3D-View, the beams are displayed very fanned.
In the unit there are RGBW LEDs. Could them be showed as strong lines in the 3D?
(Unfortunately, the 4 LEDs (RGBW) of the individual heads do not mix on this device.
In reality You therefore see 1-4 rgbw dots on the projection surface (in my case the ceiling).
So 4 closely spaced colored lines (RGBW) per head would look more realistic than a colored beam.
I don´t know, if this is possible for the 3D-Window)
Problem2: The movements in the 3D window are not adequate to reality.
Can I do something about this (reset) or does the fixture have to be changed?
Thank You in advance for Your help
Greetings
Sven
3DView is supposed to show only these kind of DMX fixtures: https://forum.thelightingcontroller.com ... .php?t=668
We have added some more functions to allow to show more complex ones, but this is not perfect.
Sorry for that.
Svenino
Post by Svenino »
Thank You, but it´s only 5 moving heads in a row (on a bar).
Nothing like "frost", "shake" or other complex stuff.
The 3D view is obviously working correct.
The 3D view shows the 5 beams and the movement of them.
Just theCoordinates are not correctly adjusted and
I´m asking You kindly for modifying the expansion of the beams in the 3Dview.
So it´s not done with an Explanation but You could kindly help me.
I would be very thankful for Your assistence, because I baught the USB-DMX D512S special for Sweetlight-Software,
but can´t use the hardware in my office, but have to develope lightshows there.
I NEED the 3D View working fine with the fixture.
Thank you for your effort and understanding
Sven Loichen
Please post a link to download your lightshow and give more details.
https://forum.thelightingcontroller.com ... .php?t=168
Please give more details on this too.
Svenino
Post by Svenino »
The expansion of the beams I could adjust.
Although there are not 4 differently colored lines showen, the beams are now at least thinner.
(edit fixture / view / beam aperture)
The Coordinates aren´t right but:
Biggest problem now is, that only now I realize, that no hardware-sliders or midi controllers work in the Step-Editor.
I´ve trusted in a good support, when bying an unusually expensive USB-DMX Interface necessary for Your software.
But I've seen forum requests from 2023 that want the same thing.
What's so hard about linking those screen sliders to hardware sliders?
(a learn option for midi controllers would also be possible here)
For positioning several moving heads and programming many lightshows with them
the mouse is not really an option for this.
This missing feature ruins your beautiful software. Please change this!
I´m sorry, but this is necessary for a reasonably good workflow...
Greetings
Sven Loichen
Svenino
Post by Svenino »
request - MIDI faders to faders in Steps
Post by pikip72 » 19 August 2021, 21:13
