Is there a way to create a transparent button? Say I have a my lights strobing red. Instead of creating the same scenes with different colors, is there a way to play a scene on top of another one so the color changes of the strobing color. Not sure if you understand what I'm trying to say but I can elaborate a little more if you need me to.
Thanks!!!
Transparent Buttons [fixed]
Sound Storms Ent.
Re: Transparent Buttons
Very simple here......
Make "buttons" for your colors only. In other words when creating the sceen ONLY use your color faders and DO NOT touch your dimmer/strobe/shutter slider AT ALL!
Then make a "button" that activates your strobe function ONLY do not touch your color sliders at all. You can also do this for a 100% bright and a 50% bright on your dimmer.
What you are now able to do is click you "100%" button and then choose your color and constantly chose new colors...... OR use your "strobe" button and constantly change colors while still strobe by useing your SAME "color" buttons.
Hope this helps.
Hope this helps.
