Stand Alone Calendar Error
leemanpa
Post by leemanpa »
USing the 512 Remote with only 1 Universe, only ONE scene programmed into 512 set to turn on at 6pm, off at 1159pm... The scene turns on as soon as the 512 is connected and never turns off, except when the 512 is either disconnected or the power switch is flipped to external. What gives???
Re: Stand Alone Calendar Error
If we right understand, the problem is: the running scene is lost when the interface is either disconnected or the power switch is flipped to external (?)
If yes, this is normal, since the interface does not know what was happening before the power on.
leemanpa
Post by leemanpa »
No, the scene uploads fine. It just stays on all the time, regardless of the schedule. Once it turns on, it never turns off, unless turned off manually. I want it to start at 6pm, and turn off at 11pm, every day.
We are not able to reproduce this problem (for more convenience, we tried with only one minute between "on" and "off" states).
Are you also able to see the problem with a period of only one minute (for instance "on" at 6:00pm and "off" at 6:01pm) ?
Can you send us a backup of your lightshow ? We will check it.
leemanpa
Post by leemanpa »
Absolutely... Enclosed is a copy of the scene, as well as a screenshot of the stand-alone. Note the settings, note the time. The lights are ON right now, and have been all day.
We see that button #1 has the "start = yes" option.
"start = yes" means "start at interface power on".
Please change this option to "start = no" ; then it should work better.
Return to “Remote”
