I am using Show Express 6.271 on a Win 7 32 bit system. When I save a scene using Save As. Then name it and save it. When I am looking at the editor screen again. If I bring the mouse arrow over any of the Channel faders, they seem to go crazy and move. I am not clicking them or trying to make them move. You can literally just pass the pointer over the faders and they will move on thier own.
Odly enough, the movements do not get saved on that step. If you click on another step and then back to the selected step you were on, you will find your step intact. But this should not happen as far as I can tell. Any help would be appreciated!
Channel faders go crazy and move [fixed]
Re: Possible bug after using Save As - 6.271
We are presently not able to reproduce this problem.
It seems we need to make a specific procedure to get it.
Can you please tell us exactely the procedure to get this problem ?
Sure, think I norrowed it down a bit.
Open an already created scene
Edit the scene (optional)
Go to File and then Save As
Name it (anything, same name, even "1" works) and hit save
When you are back at the editor screen, take a look at what step is selected in the step/duration window (top middle, just for note)
Now move the mouse pointer over any slider that is not already on 0 (the sliders only drop to 0) - This is the main problem
If I select another step and then go back to the one I was just on, the scene is still intact even though the sliders moved.
Hope this helps, thanks for the quick response.
Fixed for next release.
Great! Thanks.
Available in "fix_for_xxx.zip" files.
Re: Channel faders go crazy and move [fixed]
Not sure where to find that fix. I am very new to this forum, sorry. Is this under FAQ's then "All the files you need"? I saw fixes there, but did not see any files with that nameing convention.
Thanks again for the help.
Thanks, works perfect!
