ledpars react strange [fixed]
marco
Post by marco »
hi got a problem with my ledpars in 3d
in 1 show they work normal in an other show they stay white, try to ajust the profile, copy the profile from 1 show to the other but nothing work
can u have a look?
greets marco
marco
Re: ledpars react strange
Post by marco »
the show maasmarco is the one with the ledpars always on
the sophies is the one thats work normal
marco
Post by marco »
hi an update
been experimenting the last day an found a solution
if i change the channel color into color macro it works again (Channel 4)
only strange that in one show it works normal in the other i have to change the profile
greets Marco
This is certainely because they are two different software versions on the two computers.
We recently made some code change in this area, for a better management of CMY colors.
The modification you did might be necessary with new software version.
marco
Re: ledpars react strange [fixed]
Post by marco »
hi
the problem was on the same laptop i just switch the show i use 6.271
not on 2 different ones
greetz marco
Noted.
So this will remain a bit weird, but the most important is you found a solution.
