American DJ - Comscan & Blizzard - Puck 3
sarellano
Post by sarellano »
I am looking for the profiles on the Comscan and also Puck 3. Where do I find them?
Thank you!
tomrbland
Re: Question
Post by tomrbland »
sarellano
Re: Question
Post by sarellano »
I go to that directory and it's just a txt file. I does not let me download anything. I am very new to this as you can tell. I was thinking I needed a different type of file foe the fixture profiles?
tomrbland
Re: Question
Post by tomrbland »
You need to give a link to the Comscan and the Puck 3's manual then the profiles will be built for you, if they are not in the library already. You haven't specified what make your fixtures are; who makes the Comscan?
If you found the text file with the profile that you require then just right click it, press save as and:
- then, in application Setup, you can import the file in your lightshow. Alternatively, you can copy the file here: "home_directory/LightShow/YourShow/fixtures/" (since version 6.24, it is possible to open the "home_directory/LightShow/" folder from ControlBoard > Settings)."
sarellano
Re: Question
Post by sarellano »
Let me try what you suggested. American DJ makes the Comscan and Blizzard Lighting makes the Puck 3. I see they have been built, but I guess I need to download the text.
Thank you!
