Fade In and Fade Out on StandAlone mode
costas
Post by costas »
We have a project that we use Sweetlight Interface RACK1024. We want to add a fade in/out time on a scene when we trigger the scene from a dry contact. For example, triggering dry contact 1 then RED scene starts with a fade in time 5sec stays RED until we trigger again the same contact and fade out in 5sec. Same thing if we trigger another contact let's say green on contact 2. So we want to have a mix with fade in and fade out on 2 scenes. How we can produce that?
Re: Fade In and Fade Out on StandAlone mode
When you press the button to switch on, the "fade in" time is the duration of the first step of the scene.
When you press the button again, the channels switch off immediately.
You have to leave the first button on and press a new button on to get a fade transition.
The new button can have the channels at level 0.
costas
Post by costas »
Hello support,
When I press the button or closing a dry contact the scene starts to play the first step and the fade in is indeed the duration of the first step.
The issue is that the scenes when you add steps they are looping. So how we can select to have a color for as long we decide with a fade in?
You can set a very long duration to the last step.
Return to “StandAlone”
