Repeated Crashes 9.3.8 [fixed]
ChaseThe28
Post by ChaseThe28 »
I'm getting repeated crashes this morning and it seems a bit random.
I'm running 9.3.8 on an M1 Max MBP with Sonoma 14.4.1
Any input or fixes gratefully received
This is the error log:
Translated Report (Full Report Below)
Process: TheLightingController [94929]
Path: /Applications/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2024-05-16 12:53:25.0036 +0100
OS Version: macOS 14.4.1 (23E224)
Report Version: 12
Anonymous UUID: E11DA62D-1A11-4AAC-C042-C9EFA1C4F23A
Sleep/Wake UUID: E4112E62-53D5-41B2-8E4F-A9472414C4CE
Time Awake Since Boot: 150000 seconds
Time Since Wake: 18699 seconds
System Integrity Protection: enabled
Notes:
PC register does not match crashing frame (0x0 vs 0x1000F5E7D)
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000018
Exception Codes: 0x0000000000000001, 0x0000000000000018
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [94929]
VM Region Info: 0x18 is not in any region. Bytes before following region: 4294967272
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 100000000-1002d8000 [ 2912K] r-x/r-x SM=COW /Applications/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController
Error Formulating Crash Report:
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 TheLightingController 0x1000f5e7d 0x100000000 + 1007229
1 TheLightingController 0x1000e5969 0x100000000 + 940393
Thread 1:: com.apple.rosetta.exceptionserver
0 runtime 0x7ff7ffbe7494 0x7ff7ffbe3000 + 17556
Thread 2:
0 ??? 0x7ff89d976a78 ???
1 libsystem_kernel.dylib 0x7ff80d6e2e46 __semwait_signal + 10
2 libsystem_c.dylib 0x7ff80d5d5531 nanosleep + 199
3 TheLightingController 0x1001b2a87 0x100000000 + 1780359
4 TheLightingController 0x1000bd9b2 0x100000000 + 776626
5 ??? 0xffd0d0d0 ???
Thread 3:: com.apple.NSEventThread
1 libsystem_kernel.dylib 0x7ff80d6e03ce mach_msg2_trap + 10
2 libsystem_kernel.dylib 0x7ff80d6eec88 mach_msg2_internal + 84
3 libsystem_kernel.dylib 0x7ff80d6e7510 mach_msg_overwrite + 653
4 libsystem_kernel.dylib 0x7ff80d6e06bd mach_msg + 19
5 CoreFoundation 0x7ff80d7fd359 __CFRunLoopServiceMachPort + 143
6 CoreFoundation 0x7ff80d7fbdcc __CFRunLoopRun + 1371
7 CoreFoundation 0x7ff80d7fb2a9 CFRunLoopRunSpecific + 557
8 AppKit 0x7ff810f21abc _NSEventThread + 122
9 libsystem_pthread.dylib 0x7ff80d72018b _pthread_start + 99
10 libsystem_pthread.dylib 0x7ff80d71bae3 thread_start + 15
Thread 4:
4 TheLightingController 0x100012c20 0x100000000 + 76832
5 ??? 0x304a01000 ???
Thread 5:
1 libsystem_kernel.dylib 0x7ff80d6e2f7a __psynch_cvwait + 10
2 libsystem_pthread.dylib 0x7ff80d7206f3 _pthread_cond_wait + 1211
3 TheLightingController 0x10018c8ab 0x100000000 + 1624235
4 TheLightingController 0x100013d8b 0x100000000 + 81291
Thread 6:
5 CoreMIDI 0x7ff828daae52 XServerMachPort::ReceiveMessage(int&, void*, int&) + 98
6 CoreMIDI 0x7ff828dba8ba MIDIProcess::MIDIInPortThread::Run() + 104
7 CoreMIDI 0x7ff828db7ed6 CADeprecated::XThread::RunHelper(void*) + 10
8 CoreMIDI 0x7ff828db9903 CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*) + 77
Thread 7:
4 TheLightingController 0x100142aa3 0x100000000 + 1321635
5 ??? 0x1000f ???
Thread 8:
5 ??? 0x1000e ???
Thread 9:
0 runtime 0x7ff7ffc0594c 0x7ff7ffbe3000 + 141644
Thread 10:
Thread 11:: Dispatch queue: com.apple.coreanimation.mtl_dealloc
1 IOKit 0x7ff810c81512 iokit_user_client_trap + 10
2 IOKit 0x7ff810c800af IOConnectTrap1 + 28
3 IOGPU 0x7ff90e4d4906 ioGPUResourceFinalize + 89
4 CoreFoundation 0x7ff80d8c61ad _CFRelease + 281
5 IOGPU 0x7ff90e4ce65f -[IOGPUMetalResource dealloc] + 295
6 IOGPU 0x7ff90e4d0014 -[IOGPUMetalTexture dealloc] + 299
7 AGXMetalG13X 0x7ffa25634d87 -[AGXTexture dealloc] + 39
8 AGXMetalG13X 0x7ffa252856e6 -[AGXG13XFamilyTexture dealloc] + 166
9 QuartzCore 0x7ff8164d2aaf invocation function for block in CA::OGL::MetalContext::delete_image(CA::OGL::Image*) + 35
10 libdispatch.dylib 0x7ff80d57dac6 _dispatch_call_block_and_release + 12
11 libdispatch.dylib 0x7ff80d57edbc _dispatch_client_callout + 8
12 libdispatch.dylib 0x7ff80d584eff _dispatch_lane_serial_drain + 800
13 libdispatch.dylib 0x7ff80d585997 _dispatch_lane_invoke + 377
14 libdispatch.dylib 0x7ff80d584d62 _dispatch_lane_serial_drain + 387
15 libdispatch.dylib 0x7ff80d585997 _dispatch_lane_invoke + 377
16 libdispatch.dylib 0x7ff80d58f414 _dispatch_root_queue_drain_deferred_wlh + 271
17 libdispatch.dylib 0x7ff80d58ed2a _dispatch_workloop_worker_thread + 451
18 libsystem_pthread.dylib 0x7ff80d71cb84 _pthread_wqthread + 327
19 libsystem_pthread.dylib 0x7ff80d71bacf start_wqthread + 15
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000100003790 rcx: 0x00007f82bf11f588 rdx: 0x00000001001af60b
rdi: 0x000000000000010e rsi: 0x00000001001af64c rbp: 0x0000000000000000 rsp: 0x00000003045e2820
r8: 0x00006000030cb958 r9: 0x00000000ffffff00 r10: 0x00000001002ef688 r11: 0x00000001001af530
r12: 0x0000000109401bd0 r13: 0x0000000109401d58 r14: 0x0000000000000189 r15: 0x0000000000000016
rip: <unavailable> rfl: 0x0000000000000202
tmp0: 0x0000000000000000 tmp1: 0x00000001000f5e5b tmp2: 0x00000001005ed8b4
Binary Images:
0x2004fb000 - 0x20058bfff dyld (*) <899f1e34-b624-3162-8003-04daa6829461> /usr/lib/dyld
0x114c6c000 - 0x114c74fff com.apple.iokit.IOUSBLib (900.4.2) <e3f33b43-58a0-3425-8c2f-0dd521b86f78> /System/Library/Extensions/IOUSBHostFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x114ca3000 - 0x114ca6fff efk_usb.dylib (*) <a49127b6-b5bf-390a-9b73-51ddf560021b> /Applications/ShowXpress/efk_usb.dylib
0x114345000 - 0x114370fff efk_hardware.dylib (*) <d4ce1c64-3d5e-3543-b04b-9ab003e48f27> /Applications/ShowXpress/efk_hardware.dylib
0x11339d000 - 0x1133a9fff libobjc-trampolines.dylib (*) <3d9756e6-f86a-324d-bfd7-dc2d59c27956> /usr/lib/libobjc-trampolines.dylib
0x7ff7ffbe3000 - 0x7ff7ffc12fff runtime (*) <cac146cd-fadd-39a0-8bd7-30c2e15d10cf> /usr/libexec/rosetta/runtime
0x10899f000 - 0x1089f2fff libRosettaRuntime (*) <8a85f070-3849-3b55-adde-143cc5902f92> /Library/Apple/*/libRosettaRuntime
0x100000000 - 0x1002d7fff TheLightingController (*) <0a13109d-5b55-349e-9ec5-cb037fb57a77> /Applications/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x7ff80d6df000 - 0x7ff80d719ff7 libsystem_kernel.dylib (*) <50c9fa25-ed67-32a5-88f4-92de497b0ec1> /usr/lib/system/libsystem_kernel.dylib
0x7ff80d5c6000 - 0x7ff80d64dff7 libsystem_c.dylib (*) <6d02e870-f215-36ed-bf7d-435f66996bfe> /usr/lib/system/libsystem_c.dylib
0x7ff80d781000 - 0x7ff80dc1affc com.apple.CoreFoundation (6.9) <03688667-a025-352f-81e2-612c65b6bce3> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff810d86000 - 0x7ff8121b3ff5 com.apple.AppKit (6.9) <4905ef83-f061-3c82-bc30-70a4def63eee> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff80d71a000 - 0x7ff80d725ff7 libsystem_pthread.dylib (*) <5a006814-83f4-3c80-ab1f-528cdd08c0ff> /usr/lib/system/libsystem_pthread.dylib
0x7ff828d79000 - 0x7ff828e04ff5 com.apple.audio.midi.CoreMIDI (2.0) <27cf6aa9-5a17-3bd2-b06a-3f49d8686657> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7ff810c5d000 - 0x7ff810d20fff com.apple.framework.IOKit (2.0.2) <bd7f61c1-f17d-3ae7-beb6-2c4bc2d19535> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7ff90e4bd000 - 0x7ff90e4f4ff3 com.apple.IOGPU (93.40.3) <cf4746a3-bea9-3f23-a48e-8c4c55b5f8b0> /System/Library/PrivateFrameworks/IOGPU.framework/Versions/A/IOGPU
0x7ffa24e06000 - 0x7ffa2567dff0 com.apple.AGXMetalG13X (280.3.9) <9c586647-c62a-3189-8b75-b41cf5fe8044> /System/Library/Extensions/AGXMetalG13X.bundle/Contents/MacOS/AGXMetalG13X
0x7ff8162b1000 - 0x7ff81663bffd com.apple.QuartzCore (1.11) <0f2e1014-b662-3599-b876-cad02f73b896> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7ff80d57c000 - 0x7ff80d5c2ff1 libdispatch.dylib (*) <85907582-b9ae-3a02-baca-2da374c6fbac> /usr/lib/system/libdispatch.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=831.2M resident=0K(0%) swapped_out_or_unallocated=831.2M(100%)
Writable regions: Total=2.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.0G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG image 44.6M 528
ColorSync 264K 33
CoreAnimation 6820K 92
CoreGraphics 12K 2
CoreServices 176K 1
CoreUI image data 4756K 39
Foundation 40K 2
Kernel Alloc Once 8K 1
MALLOC 1.7G 76
MALLOC guard page 192K 12
Rosetta Arena 4096K 2
Rosetta Generic 1272K 315
Rosetta IndirectBranch 1024K 1
Rosetta JIT 128.0M 1
Rosetta Return Stack 220K 22
Rosetta Thread Context 220K 22
STACK GUARD 8K 2
Stack 15.6M 11
Stack Guard 56.0M 9
VM_ALLOCATE 18.6M 69
VM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)
__CTF 824 1
__DATA 35.3M 598
__DATA_CONST 41.5M 386
__DATA_DIRTY 1761K 212
__FONT_DATA 2352 1
__INFO_FILTER 8 1
__LINKEDIT 137.5M 12
__OBJC_RO 71.7M 1
__OBJC_RW 2193K 2
__TEXT 693.8M 617
dyld private memory 4360K 4
mapped file 224.0M 57
shared memory 1340K 20
TOTAL 3.2G 3156
TOTAL, minus reserved VM space 3.2G 3156
Full Report
{"app_name":"TheLightingController","timestamp":"2024-05-16 12:53:25.00 +0100","app_version":"","slice_uuid":"0a13109d-5b55-349e-9ec5-cb037fb57a77","build_version":"0.1","platform":1,"share_with_app_devs":0,"is_first_party":1,"bug_type":"309","os_version":"macOS 14.4.1 (23E224)","roots_installed":0,"incident_id":"BE8A2AA6-9CCC-48BC-8A81-CB50F79245FD","name":"TheLightingController"}
"uptime" : 150000,
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookPro18,4",
"coalitionID" : 17556,
"osVersion" : {
"train" : "macOS 14.4.1",
"build" : "23E224",
"releaseType" : "User"
"captureTime" : "2024-05-16 12:53:25.0036 +0100",
"codeSigningMonitor" : 1,
"incident" : "BE8A2AA6-9CCC-48BC-8A81-CB50F79245FD",
"pid" : 94929,
"translated" : true,
"cpuType" : "X86-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2024-05-16 12:49:02.7712 +0100",
"procStartAbsTime" : 3820828505248,
"procExitAbsTime" : 3827121215413,
"procName" : "TheLightingController",
"procPath" : "\/Applications\/ShowXpress\/TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"bundleInfo" : {"CFBundleVersion":"0.1"},
"parentProc" : "launchd",
"parentPid" : 1,
"crashReporterKey" : "E11DA62D-1A11-4AAC-C042-C9EFA1C4F23A",
"codeSigningID" : "TheLightingController",
"codeSigningTeamID" : "Y37848Q249",
"codeSigningFlags" : 570503953,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"wakeTime" : 18699,
"sleepWakeUUID" : "E4112E62-53D5-41B2-8E4F-A9472414C4CE",
"sip" : "enabled",
"vmRegionInfo" : "0x18 is not in any region. Bytes before following region: 4294967272\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 100000000-1002d8000 [ 2912K] r-x\/r-x SM=COW \/Applications\/ShowXpress\/TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"exception" : {"codes":"0x0000000000000001, 0x0000000000000018","rawCodes":[1,24],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000018"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":94929},
"vmregioninfo" : "0x18 is not in any region. Bytes before following region: 4294967272\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 100000000-1002d8000 [ 2912K] r-x\/r-x SM=COW \/Applications\/ShowXpress\/TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":2831244,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":0},"r12":{"value":4450163664},"rosetta":{"tmp2":{"value":4301183156},"tmp1":{"value":4295974491},"tmp0":{"value":0}},"rbx":{"value":4294981520},"r8":{"value":105553167432024},"r15":{"value":22},"r10":{"value":4298045064},"rdx":{"value":4296734219},"rdi":{"value":270},"r9":{"value":4294967040},"r13":{"value":4450164056},"rflags":{"value":514},"rax":{"value":0},"rsp":{"value":12958181408},"r11":{"value":4296734000},"rcx":{"value":140199528101256},"r14":{"value":393},"rsi":{"value":4296734284}},"queue":"com.apple.main-thread","frames":[{"imageOffset":1007229,"imageIndex":7},{"imageOffset":940393,"imageIndex":7}]},{"id":2831250,"name":"com.apple.rosetta.exceptionserver","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":406299611234304},"r12":{"value":140705777870928},"rosetta":{"tmp2":{"value":240518173971},"tmp1":{"value":406299611234563},"tmp0":{"value":15586436317184}},"rbx":{"value":406299611234563},"r8":{"value":240518173971},"r15":{"value":4831842304},"r10":{"value":15586436317184},"rdx":{"value":240518173971},"rdi":{"value":0},"r9":{"value":406299611234563},"r13":{"value":4439690112},"rflags":{"value":582},"rax":{"value":0},"rsp":{"value":15586436317184},"r11":{"value":24},"rcx":{"value":8589934595},"r14":{"value":4301183204},"rsi":{"value":44}},"frames":[{"imageOffset":17556,"imageIndex":5}]},{"id":2831268,"frames":[{"imageOffset":140705772563064,"imageIndex":8},{"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":9},{"imageOffset":62769,"symbol":"nanosleep","symbolLocation":199,"imageIndex":10},{"imageOffset":1780359,"imageIndex":7},{"imageOffset":776626,"imageIndex":7},{"imageOffset":4291875024,"imageIndex":8}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":50000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703353941564},"tmp1":{"value":140705772563020},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":1450216108589215463},"r9":{"value":50000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":105553146415200},"rcx":{"value":0},"r14":{"value":12960902960},"rsi":{"value":26899}}},{"id":2831276,"name":"com.apple.NSEventThread","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":186929861623808},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703353990280},"tmp1":{"value":140705772563304},"tmp0":{"value":18446744073709551615}},"rbx":{"value":186929861623808},"r8":{"value":0},"r15":{"value":186929861623808},"r10":{"value":186929861623808},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":186929861623808},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705772563064,"imageIndex":8},{"imageOffset":5070,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":9},{"imageOffset":64648,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":9},{"imageOffset":34064,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":9},{"imageOffset":5821,"symbol":"mach_msg","symbolLocation":19,"imageIndex":9},{"imageOffset":508761,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":11},{"imageOffset":503244,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageIndex":11},{"imageOffset":500393,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":11},{"imageOffset":1686204,"symbol":"_NSEventThread","symbolLocation":122,"imageIndex":12},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":2831332,"frames":[{"imageOffset":140705772563064,"imageIndex":8},{"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":9},{"imageOffset":62769,"symbol":"nanosleep","symbolLocation":199,"imageIndex":10},{"imageOffset":1780359,"imageIndex":7},{"imageOffset":76832,"imageIndex":7},{"imageOffset":12962500608,"imageIndex":8}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":10000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703353941564},"tmp1":{"value":140705772563020},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":12962500608},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":1598178805678239463},"r9":{"value":10000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":12962500368},"rsi":{"value":4296592224}}},{"id":2831333,"frames":[{"imageOffset":140705772563064,"imageIndex":8},{"imageOffset":16250,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":9},{"imageOffset":26355,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":1624235,"imageIndex":7},{"imageOffset":81291,"imageIndex":7},{"imageOffset":12962500608,"imageIndex":8}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703353941872},"tmp1":{"value":140705772563020},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703354200509,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":12963561472},"rsi":{"value":0}}},{"id":2831334,"frames":[{"imageOffset":140705772563064,"imageIndex":8},{"imageOffset":5070,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":9},{"imageOffset":64648,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":9},{"imageOffset":34064,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":9},{"imageOffset":5821,"symbol":"mach_msg","symbolLocation":19,"imageIndex":9},{"imageOffset":204370,"symbol":"XServerMachPort::ReceiveMessage(int&, void*, int&)","symbolLocation":98,"imageIndex":14},{"imageOffset":268474,"symbol":"MIDIProcess::MIDIInPortThread::Run()","symbolLocation":104,"imageIndex":14},{"imageOffset":257750,"symbol":"CADeprecated::XThread::RunHelper(void*)","symbolLocation":10,"imageIndex":14},{"imageOffset":264451,"symbol":"CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*)","symbolLocation":77,"imageIndex":14},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":362851722067968},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703353990280},"tmp1":{"value":140705772563304},"tmp0":{"value":18446744073709551615}},"rbx":{"value":362851722067968},"r8":{"value":0},"r15":{"value":362851722067968},"r10":{"value":362851722067968},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":362851722067968},"r13":{"value":17179869186},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":100},"rcx":{"value":17179869186},"r14":{"value":100},"rsi":{"value":100}}},{"id":2831341,"frames":[{"imageOffset":140705772563064,"imageIndex":8},{"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":9},{"imageOffset":62769,"symbol":"nanosleep","symbolLocation":199,"imageIndex":10},{"imageOffset":1780359,"imageIndex":7},{"imageOffset":1321635,"imageIndex":7},{"imageOffset":65551,"imageIndex":8}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":1000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703353941564},"tmp1":{"value":140705772563020},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":1598049239399821031},"r9":{"value":1000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":60},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":12965158640},"rsi":{"value":12965158656}}},{"id":2831347,"frames":[{"imageOffset":140705772563064,"imageIndex":8},{"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":9},{"imageOffset":62769,"symbol":"nanosleep","symbolLocation":199,"imageIndex":10},{"imageOffset":1780359,"imageIndex":7},{"imageOffset":1321635,"imageIndex":7},{"imageOffset":65550,"imageIndex":8}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":10000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703353941564},"tmp1":{"value":140705772563020},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":1581308174139551463},"r9":{"value":10000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":12967325424},"rsi":{"value":12967325440}}},{"id":2833475,"frames":[{"imageOffset":141644,"imageIndex":5}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":12958748672},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":12959285248},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":69895},"r14":{"value":0},"rsi":{"value":0}}},{"id":2836109,"frames":[{"imageOffset":141644,"imageIndex":5}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":12958191616},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":12958728192},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":96791},"r14":{"value":0},"rsi":{"value":0}}},{"id":2836257,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":0},"r12":{"value":281474976747776},"rosetta":{"tmp2":{"value":140703410159791},"tmp1":{"value":140705772563016},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":12967884064},"r15":{"value":18446462598732840960},"r10":{"value":0},"rdx":{"value":43},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":140708720699032,"symbolLocation":0,"symbol":"kIOGPUResourceClass"},"rflags":{"value":659},"rax":{"value":0},"rsp":{"value":0},"r11":{"value":140707663478020,"symbolLocation":0,"symbol":"-[IOGPUMetalDevice _removeResource:]"},"rcx":{"value":1},"r14":{"value":43},"rsi":{"value":0}},"queue":"com.apple.coreanimation.mtl_dealloc","frames":[{"imageOffset":140705772563064,"imageIndex":8},{"imageOffset":148754,"symbol":"iokit_user_client_trap","symbolLocation":10,"imageIndex":15},{"imageOffset":143535,"symbol":"IOConnectTrap1","symbolLocation":28,"imageIndex":15},{"imageOffset":96518,"symbol":"ioGPUResourceFinalize","symbolLocation":89,"imageIndex":16},{"imageOffset":1331629,"symbol":"_CFRelease","symbolLocation":281,"imageIndex":11},{"imageOffset":71263,"symbol":"-[IOGPUMetalResource dealloc]","symbolLocation":295,"imageIndex":16},{"imageOffset":77844,"symbol":"-[IOGPUMetalTexture dealloc]","symbolLocation":299,"imageIndex":16},{"imageOffset":8580487,"symbol":"-[AGXTexture dealloc]","symbolLocation":39,"imageIndex":17},{"imageOffset":4716262,"symbol":"-[AGXG13XFamilyTexture dealloc]","symbolLocation":166,"imageIndex":17},{"imageOffset":2235055,"symbol":"invocation function for block in CA::OGL::MetalContext::delete_image(CA::OGL::Image*)","symbolLocation":35,"imageIndex":18},{"imageOffset":6854,"symbol":"_dispatch_call_block_and_release","symbolLocation":12,"imageIndex":19},{"imageOffset":11708,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":19},{"imageOffset":36607,"symbol":"_dispatch_lane_serial_drain","symbolLocation":800,"imageIndex":19},{"imageOffset":39319,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":19},{"imageOffset":36194,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":19},{"imageOffset":39319,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":19},{"imageOffset":78868,"symbol":"_dispatch_root_queue_drain_deferred_wlh","symbolLocation":271,"imageIndex":19},{"imageOffset":77098,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":451,"imageIndex":19},{"imageOffset":11140,"symbol":"_pthread_wqthread","symbolLocation":327,"imageIndex":13},{"imageOffset":6863,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":13}]}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 8595156992,
"size" : 593920,
"uuid" : "899f1e34-b624-3162-8003-04daa6829461",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "x86_64",
"base" : 4643536896,
"CFBundleShortVersionString" : "900.4.2",
"CFBundleIdentifier" : "com.apple.iokit.IOUSBLib",
"size" : 36864,
"uuid" : "e3f33b43-58a0-3425-8c2f-0dd521b86f78",
"path" : "\/System\/Library\/Extensions\/IOUSBHostFamily.kext\/Contents\/PlugIns\/IOUSBLib.bundle\/Contents\/MacOS\/IOUSBLib",
"name" : "IOUSBLib",
"CFBundleVersion" : "900.4.2"
"source" : "P",
"arch" : "x86_64",
"base" : 4643762176,
"size" : 16384,
"uuid" : "a49127b6-b5bf-390a-9b73-51ddf560021b",
"path" : "\/Applications\/ShowXpress\/efk_usb.dylib",
"name" : "efk_usb.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4633939968,
"size" : 180224,
"uuid" : "d4ce1c64-3d5e-3543-b04b-9ab003e48f27",
"path" : "\/Applications\/ShowXpress\/efk_hardware.dylib",
"name" : "efk_hardware.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4617523200,
"size" : 53248,
"uuid" : "3d9756e6-f86a-324d-bfd7-dc2d59c27956",
"path" : "\/usr\/lib\/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "arm64",
"base" : 140703124303872,
"size" : 196608,
"uuid" : "cac146cd-fadd-39a0-8bd7-30c2e15d10cf",
"path" : "\/usr\/libexec\/rosetta\/runtime",
"name" : "runtime"
"source" : "P",
"arch" : "arm64",
"base" : 4439273472,
"size" : 344064,
"uuid" : "8a85f070-3849-3b55-adde-143cc5902f92",
"path" : "\/Library\/Apple\/*\/libRosettaRuntime",
"name" : "libRosettaRuntime"
"source" : "P",
"arch" : "x86_64",
"base" : 4294967296,
"size" : 2981888,
"uuid" : "0a13109d-5b55-349e-9ec5-cb037fb57a77",
"path" : "\/Applications\/ShowXpress\/TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"name" : "TheLightingController",
"CFBundleVersion" : "0.1"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 140703353925632,
"size" : 241656,
"uuid" : "50c9fa25-ed67-32a5-88f4-92de497b0ec1",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703352774656,
"size" : 557048,
"uuid" : "6d02e870-f215-36ed-bf7d-435f66996bfe",
"path" : "\/usr\/lib\/system\/libsystem_c.dylib",
"name" : "libsystem_c.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703354589184,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 4825085,
"uuid" : "03688667-a025-352f-81e2-612c65b6bce3",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "2420"
"source" : "P",
"arch" : "x86_64",
"base" : 140703411232768,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 21159926,
"uuid" : "4905ef83-f061-3c82-bc30-70a4def63eee",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2487.50.124"
"source" : "P",
"arch" : "x86_64",
"base" : 140703354167296,
"size" : 49144,
"uuid" : "5a006814-83f4-3c80-ab1f-528cdd08c0ff",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703813832704,
"CFBundleShortVersionString" : "2.0",
"CFBundleIdentifier" : "com.apple.audio.midi.CoreMIDI",
"size" : 573430,
"uuid" : "27cf6aa9-5a17-3bd2-b06a-3f49d8686657",
"path" : "\/System\/Library\/Frameworks\/CoreMIDI.framework\/Versions\/A\/CoreMIDI",
"name" : "CoreMIDI",
"CFBundleVersion" : "88"
"source" : "P",
"arch" : "x86_64",
"base" : 140703410016256,
"CFBundleShortVersionString" : "2.0.2",
"CFBundleIdentifier" : "com.apple.framework.IOKit",
"size" : 802816,
"uuid" : "bd7f61c1-f17d-3ae7-beb6-2c4bc2d19535",
"path" : "\/System\/Library\/Frameworks\/IOKit.framework\/Versions\/A\/IOKit",
"name" : "IOKit"
"source" : "P",
"arch" : "x86_64",
"base" : 140707663433728,
"CFBundleShortVersionString" : "93.40.3",
"CFBundleIdentifier" : "com.apple.IOGPU",
"size" : 229364,
"uuid" : "cf4746a3-bea9-3f23-a48e-8c4c55b5f8b0",
"path" : "\/System\/Library\/PrivateFrameworks\/IOGPU.framework\/Versions\/A\/IOGPU",
"name" : "IOGPU",
"CFBundleVersion" : "93.40.3"
"source" : "P",
"arch" : "x86_64",
"base" : 140712337235968,
"CFBundleShortVersionString" : "280.3.9",
"CFBundleIdentifier" : "com.apple.AGXMetalG13X",
"size" : 8880113,
"uuid" : "9c586647-c62a-3189-8b75-b41cf5fe8044",
"path" : "\/System\/Library\/Extensions\/AGXMetalG13X.bundle\/Contents\/MacOS\/AGXMetalG13X",
"name" : "AGXMetalG13X",
"CFBundleVersion" : "280.3.9"
"source" : "P",
"arch" : "x86_64",
"base" : 140703500537856,
"CFBundleShortVersionString" : "1.11",
"CFBundleIdentifier" : "com.apple.QuartzCore",
"size" : 3715070,
"uuid" : "0f2e1014-b662-3599-b876-cad02f73b896",
"path" : "\/System\/Library\/Frameworks\/QuartzCore.framework\/Versions\/A\/QuartzCore",
"name" : "QuartzCore",
"CFBundleVersion" : "1120.22"
"source" : "P",
"arch" : "x86_64",
"base" : 140703352471552,
"size" : 290802,
"uuid" : "85907582-b9ae-3a02-baca-2da374c6fbac",
"path" : "\/usr\/lib\/system\/libdispatch.dylib",
"name" : "libdispatch.dylib"
"sharedCache" : {
"base" : 140703349751808,
"size" : 21474836480,
"uuid" : "b8d5ff9b-b3b6-327c-a409-07449b1e60da"
"vmSummary" : "ReadOnly portion of Libraries: Total=831.2M resident=0K(0%) swapped_out_or_unallocated=831.2M(100%)\nWritable regions: Total=2.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.0G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 256K 2 \nActivity Tracing 256K 1 \nCG image 44.6M 528 \nColorSync 264K 33 \nCoreAnimation 6820K 92 \nCoreGraphics 12K 2 \nCoreServices 176K 1 \nCoreUI image data 4756K 39 \nFoundation 40K 2 \nKernel Alloc Once 8K 1 \nMALLOC 1.7G 76 \nMALLOC guard page 192K 12 \nRosetta Arena 4096K 2 \nRosetta Generic 1272K 315 \nRosetta IndirectBranch 1024K 1 \nRosetta JIT 128.0M 1 \nRosetta Return Stack 220K 22 \nRosetta Thread Context 220K 22 \nSTACK GUARD 8K 2 \nStack 15.6M 11 \nStack Guard 56.0M 9 \nVM_ALLOCATE 18.6M 69 \nVM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)\n__CTF 824 1 \n__DATA 35.3M 598 \n__DATA_CONST 41.5M 386 \n__DATA_DIRTY 1761K 212 \n__FONT_DATA 2352 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 137.5M 12 \n__OBJC_RO 71.7M 1 \n__OBJC_RW 2193K 2 \n__TEXT 693.8M 617 \ndyld private memory 4360K 4 \nmapped file 224.0M 57 \nshared memory 1340K 20 \n=========== ======= ======= \nTOTAL 3.2G 3156 \nTOTAL, minus reserved VM space 3.2G 3156 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "com.apple.main-thread"
"logWritingSignature" : "ec10de0858495eff74ca7b9e585795332a37285c",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "648cada15dbc71671bb3aa1b",
"factorPackIds" : {
"SIRI_UNDERSTANDING_ATTENTION_ASSETS" : "65a8118e05d9422724106749",
"SIRI_UNDERSTANDING_ASR_ASSISTANT" : "65a8115446dfa0720068876d",
"SIRI_UNDERSTANDING_NL" : "65a811c046dfa0720068876e",
"SIRI_EXPERIENCE_CAM" : "65a81173096f6a1f1ba46525",
"SIRI_UNDERSTANDING_MORPHUN" : "65a811a96c2f903aa921c246"
"deploymentId" : 240000116
"rolloutId" : "652eff3d1bce5442b8d753c9",
"factorPackIds" : {
"deploymentId" : 240000009
"experiments" : [
"reportNotes" : [
"PC register does not match crashing frame (0x0 vs 0x1000F5E7D)"
Model: MacBookPro18,4, BootROM 10151.101.3, proc 10:8:2 processors, 64 GB, SMC
Graphics: Apple M1 Max, Apple M1 Max, Built-In
Display: Color LCD, 3024 x 1964 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4387), wl0: Jan 20 2024 04:08:41 version 20.103.12.0.8.7.171 FWID 01-e09d2675
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: USB3.0 Hub
USB Device: USB 10/100/1000 LAN
USB Device: USB2.0 Hub
USB Device: D512S
USB Device: USB 2.0 BILLBOARD
USB Device: APC MINI
Thunderbolt Bus: MacBook Pro, Apple Inc.
Re: Repeated Crashes 9.3.8
Are you using "Companion" with our software?
ChaseThe28
support wrote:Are you using "Companion" with our software?
No
Ok.
Please install the fix for version 9.3.14: https://forum.thelightingcontroller.com ... =85&t=3438
and let us know the result with this fix.
ChaseThe28
support wrote:Ok.
Thanks, installed now and will report back if it crashes again or in 24h.
Cheers
Mark
ChaseThe28
OK, just crashed again.
This is the report:
Process: TheLightingController [28209]
Version: 0.1
User ID: 501
Date/Time: 2024-05-16 20:49:07.2163 +0100
Report Version: 12
Time Awake Since Boot: 27000 seconds
Notes:
PC register does not match crashing frame (0x0 vs 0x102C66C7B)
Exception Codes: KERN_INVALID_ADDRESS at 0x47534c53202a3a41 -> 0x00004c53202a3a41 (possible pointer authentication failure)
Exception Codes: 0x0000000000000001, 0x47534c53202a3a41
Terminating Process: exc handler [28209]
VM Region Info: 0x4c53202a3a41 is not in any region. Bytes after previous region: 83438869297730 Bytes before following region: 21633210631615
commpage (reserved) 1000000000-7000000000 [384.0G] ---/--- SM=NUL reserved VM address space (unallocated)
---> GAP OF 0x5f9000000000 BYTES
MALLOC_NANO 600000000000-600020000000 [512.0M] rw-/rwx SM=PRV
0 TheLightingController 0x102c66c7b 0x102ae0000 + 1600635
1 TheLightingController 0x102c615d1 0x102ae0000 + 1578449
2 TheLightingController 0x102bef93c 0x102ae0000 + 1112380
3 TheLightingController 0x102c51287 0x102ae0000 + 1512071
4 TheLightingController 0x102c35a5d 0x102ae0000 + 1399389
5 TheLightingController 0x102b12bd1 0x102ae0000 + 207825
6 TheLightingController 0x102afd360 0x102ae0000 + 119648
7 dyld 0x202f61366 start + 1942
0 runtime 0x7ff7ffd72494 0x7ff7ffd6e000 + 17556
Thread 2:
0 runtime 0x7ff7ffd9094c 0x7ff7ffd6e000 + 141644
Thread 3:
Thread 4:
0 ??? 0x7ff8aafc6a78 ???
1 libsystem_kernel.dylib 0x7ff81ad32e46 __semwait_signal + 10
2 libsystem_c.dylib 0x7ff81ac25531 nanosleep + 199
3 TheLightingController 0x102caec67 0x102ae0000 + 1895527
4 TheLightingController 0x102afe3fa 0x102ae0000 + 123898
5 TheLightingController 0x102c88a50 0x102ae0000 + 1739344
6 libsystem_pthread.dylib 0x7ff81ad7018b _pthread_start + 99
7 libsystem_pthread.dylib 0x7ff81ad6bae3 thread_start + 15
Thread 5:: com.apple.NSEventThread
1 libsystem_kernel.dylib 0x7ff81ad303ce mach_msg2_trap + 10
2 libsystem_kernel.dylib 0x7ff81ad3ec88 mach_msg2_internal + 84
3 libsystem_kernel.dylib 0x7ff81ad37510 mach_msg_overwrite + 653
4 libsystem_kernel.dylib 0x7ff81ad306bd mach_msg + 19
5 CoreFoundation 0x7ff81ae4d359 __CFRunLoopServiceMachPort + 143
6 CoreFoundation 0x7ff81ae4bdcc __CFRunLoopRun + 1371
7 CoreFoundation 0x7ff81ae4b2a9 CFRunLoopRunSpecific + 557
8 AppKit 0x7ff81e571abc _NSEventThread + 122
9 libsystem_pthread.dylib 0x7ff81ad7018b _pthread_start + 99
10 libsystem_pthread.dylib 0x7ff81ad6bae3 thread_start + 15
Thread 6:
4 TheLightingController 0x102b34395 0x102ae0000 + 344981
Thread 7:
1 libsystem_kernel.dylib 0x7ff81ad32f7a __psynch_cvwait + 10
2 libsystem_pthread.dylib 0x7ff81ad706f3 _pthread_cond_wait + 1211
3 TheLightingController 0x102c8873b 0x102ae0000 + 1738555
4 TheLightingController 0x102b370d9 0x102ae0000 + 356569
5 TheLightingController 0x102b3456a 0x102ae0000 + 345450
6 TheLightingController 0x102c88a50 0x102ae0000 + 1739344
7 libsystem_pthread.dylib 0x7ff81ad7018b _pthread_start + 99
8 libsystem_pthread.dylib 0x7ff81ad6bae3 thread_start + 15
Thread 8:
5 CoreMIDI 0x7ff8363fae52 XServerMachPort::ReceiveMessage(int&, void*, int&) + 98
6 CoreMIDI 0x7ff83640a8ba MIDIProcess::MIDIInPortThread::Run() + 104
7 CoreMIDI 0x7ff836407ed6 CADeprecated::XThread::RunHelper(void*) + 10
8 CoreMIDI 0x7ff836409903 CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*) + 77
Thread 9:
4 TheLightingController 0x102bd9e0d 0x102ae0000 + 1023501
Thread 10:
Thread 11:
Thread 12:
rax: 0x47534c53202a3a29 rbx: 0x000000010be01bd0 rcx: 0x00000000000000b0 rdx: 0x0000000102caa31b
rdi: 0x000000000000010e rsi: 0x0000000102caa35c rbp: 0x0000000309b186b0 rsp: 0x0000000309b18600
r8: 0x0000600002373dd8 r9: 0x00000000ffffff00 r10: 0x0000000102dbb848 r11: 0x0000000102caa240
r12: 0x0000000309b22950 r13: 0x0000000000000000 r14: 0x0000000102ae4810 r15: 0x0000000309b22ad0
tmp0: 0x0000000000000016 tmp1: 0x0000000102c66c4f tmp2: 0x0000000103159b24
Binary Images:
0x202f5b000 - 0x202febfff dyld (*) <899f1e34-b624-3162-8003-04daa6829461> /usr/lib/dyld
0x117298000 - 0x1172a0fff com.apple.iokit.IOUSBLib (900.4.2) <e3f33b43-58a0-3425-8c2f-0dd521b86f78> /System/Library/Extensions/IOUSBHostFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x1172cf000 - 0x1172d2fff efk_usb.dylib (*) <a49127b6-b5bf-390a-9b73-51ddf560021b> /Applications/ShowXpress/efk_usb.dylib
0x10bc58000 - 0x10bc83fff efk_hardware.dylib (*) <551047f4-3f3d-3722-b296-aed4f64c1b3e> /Applications/ShowXpress/efk_hardware.dylib
0x10bc03000 - 0x10bc0ffff libobjc-trampolines.dylib (*) <3d9756e6-f86a-324d-bfd7-dc2d59c27956> /usr/lib/libobjc-trampolines.dylib
0x7ff7ffd6e000 - 0x7ff7ffd9dfff runtime (*) <cac146cd-fadd-39a0-8bd7-30c2e15d10cf> /usr/libexec/rosetta/runtime
0x10b39f000 - 0x10b3f2fff libRosettaRuntime (*) <8a85f070-3849-3b55-adde-143cc5902f92> /Library/Apple/*/libRosettaRuntime
0x102ae0000 - 0x102da3fff TheLightingController (*) <81e0d438-83c0-389d-9fd7-94215e83b8c3> /Applications/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController
0x7ff81ad2f000 - 0x7ff81ad69ff7 libsystem_kernel.dylib (*) <50c9fa25-ed67-32a5-88f4-92de497b0ec1> /usr/lib/system/libsystem_kernel.dylib
0x7ff81ac16000 - 0x7ff81ac9dff7 libsystem_c.dylib (*) <6d02e870-f215-36ed-bf7d-435f66996bfe> /usr/lib/system/libsystem_c.dylib
0x7ff81ad6a000 - 0x7ff81ad75ff7 libsystem_pthread.dylib (*) <5a006814-83f4-3c80-ab1f-528cdd08c0ff> /usr/lib/system/libsystem_pthread.dylib
0x7ff81add1000 - 0x7ff81b26affc com.apple.CoreFoundation (6.9) <03688667-a025-352f-81e2-612c65b6bce3> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff81e3d6000 - 0x7ff81f803ff5 com.apple.AppKit (6.9) <4905ef83-f061-3c82-bc30-70a4def63eee> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff8363c9000 - 0x7ff836454ff5 com.apple.audio.midi.CoreMIDI (2.0) <27cf6aa9-5a17-3bd2-b06a-3f49d8686657> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=828.9M resident=0K(0%) swapped_out_or_unallocated=828.9M(100%)
Writable regions: Total=2.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.1G(100%)
VIRTUAL REGION
Accelerate framework 128K 1
CG image 51.6M 468
ColorSync 244K 30
CoreAnimation 13.8M 88
CoreGraphics 12K 2
CoreUI image data 2288K 19
Foundation 40K 2
MALLOC 1.9G 91
Rosetta Generic 1320K 327
STACK GUARD 16K 4
Stack 16.1M 12
Stack Guard 56.0M 8
VM_ALLOCATE 19.6M 55
__CTF 824 1
__DATA 33.8M 555
__DATA_CONST 37.3M 355
__DATA_DIRTY 1597K 201
__FONT_DATA 2352 1
__LINKEDIT 176.4M 12
__OBJC_RO 71.7M 1
__OBJC_RW 2193K 2
__TEXT 652.5M 577
dyld private memory 260K 2
mapped file 194.6M 44
TOTAL 3.3G 2941
TOTAL, minus reserved VM space 3.3G 2941
Full Report
{"app_name":"TheLightingController","timestamp":"2024-05-16 20:49:07.00 +0100","app_version":"","slice_uuid":"81e0d438-83c0-389d-9fd7-94215e83b8c3","build_version":"0.1","platform":1,"share_with_app_devs":0,"is_first_party":1,"bug_type":"309","os_version":"macOS 14.4.1 (23E224)","roots_installed":0,"incident_id":"BEDE10EA-7368-4C08-BE70-F8C77B91B445","name":"TheLightingController"}
"uptime" : 27000,
"version" : 2,
"userID" : 501,
"coalitionID" : 4810,
"osVersion" : {
"build" : "23E224",
"captureTime" : "2024-05-16 20:49:07.2163 +0100",
"incident" : "BEDE10EA-7368-4C08-BE70-F8C77B91B445",
"pid" : 28209,
"bug_type" : "309",
"procLaunch" : "2024-05-16 20:46:30.0985 +0100",
"procStartAbsTime" : 665783176262,
"procExitAbsTime" : 669553628566,
"parentPid" : 1,
"sip" : "enabled",
"vmRegionInfo" : "0x4c53202a3a41 is not in any region. Bytes after previous region: 83438869297730 Bytes before following region: 21633210631615\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n commpage (reserved) 1000000000-7000000000 [384.0G] ---\/--- SM=NUL reserved VM address space (unallocated)\n---> GAP OF 0x5f9000000000 BYTES\n MALLOC_NANO 600000000000-600020000000 [512.0M] rw-\/rwx SM=PRV ",
"exception" : {"codes":"0x0000000000000001, 0x47534c53202a3a41","rawCodes":[1,5139535519665502785],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x47534c53202a3a41 -> 0x00004c53202a3a41 (possible pointer authentication failure)"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":28209},
"vmregioninfo" : "0x4c53202a3a41 is not in any region. Bytes after previous region: 83438869297730 Bytes before following region: 21633210631615\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n commpage (reserved) 1000000000-7000000000 [384.0G] ---\/--- SM=NUL reserved VM address space (unallocated)\n---> GAP OF 0x5f9000000000 BYTES\n MALLOC_NANO 600000000000-600020000000 [512.0M] rw-\/rwx SM=PRV ",
"threads" : [{"triggered":true,"id":690466,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13047531184},"r12":{"value":13047572816},"rosetta":{"tmp2":{"value":4346714916},"tmp1":{"value":4341525583},"tmp0":{"value":22}},"rbx":{"value":4494203856},"r8":{"value":105553153441240},"r15":{"value":13047573200},"r10":{"value":4342921288},"rdx":{"value":4341801755},"rdi":{"value":270},"r9":{"value":4294967040},"r13":{"value":0},"rflags":{"value":514},"rax":{"value":5139535519665502761},"rsp":{"value":13047531008},"r11":{"value":4341801536},"rcx":{"value":176},"r14":{"value":4339943440},"rsi":{"value":4341801820}},"queue":"com.apple.main-thread","frames":[{"imageOffset":1600635,"imageIndex":7},{"imageOffset":1578449,"imageIndex":7},{"imageOffset":1112380,"imageIndex":7},{"imageOffset":1512071,"imageIndex":7},{"imageOffset":1399389,"imageIndex":7},{"imageOffset":207825,"imageIndex":7},{"imageOffset":119648,"imageIndex":7},{"imageOffset":25446,"symbol":"start","symbolLocation":1942,"imageIndex":0}]},{"id":690476,"name":"com.apple.rosetta.exceptionserver","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":9908489551872},"r12":{"value":140706002593872},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":4462471103115},"tmp0":{"value":10337986281472}},"rbx":{"value":4462471103115},"r8":{"value":2307},"r15":{"value":4831842304},"r10":{"value":15586436317184},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":4483730304},"rflags":{"value":582},"rax":{"value":268451845},"rsp":{"value":10337986281472},"r11":{"value":5139535519665502785},"rcx":{"value":17314086914},"r14":{"value":4346714960},"rsi":{"value":2616}},"frames":[{"imageOffset":17556,"imageIndex":5}]},{"id":690491,"frames":[{"imageOffset":141644,"imageIndex":5}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13047582720},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13048119296},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":5891},"r14":{"value":0},"rsi":{"value":0}}},{"id":690492,"frames":[{"imageOffset":141644,"imageIndex":5}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13048139776},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13048676352},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":10243},"r14":{"value":0},"rsi":{"value":0}}},{"id":690513,"frames":[{"imageOffset":140705997286008,"imageIndex":8},{"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":9},{"imageOffset":62769,"symbol":"nanosleep","symbolLocation":199,"imageIndex":10},{"imageOffset":1895527,"imageIndex":7},{"imageOffset":123898,"imageIndex":7},{"imageOffset":1739344,"imageIndex":7},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":11},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":50000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703578664508},"tmp1":{"value":140705997285964},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":135319206722825466},"r9":{"value":50000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":105553132456448},"rcx":{"value":0},"r14":{"value":13050293984},"rsi":{"value":13050294064}}},{"id":690520,"name":"com.apple.NSEventThread","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":186929861623808},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703578713224},"tmp1":{"value":140705997286248},"tmp0":{"value":18446744073709551615}},"rbx":{"value":186929861623808},"r8":{"value":0},"r15":{"value":186929861623808},"r10":{"value":186929861623808},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":186929861623808},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705997286008,"imageIndex":8},{"imageOffset":5070,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":9},{"imageOffset":64648,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":9},{"imageOffset":34064,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":9},{"imageOffset":5821,"symbol":"mach_msg","symbolLocation":19,"imageIndex":9},{"imageOffset":508761,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":12},{"imageOffset":503244,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageIndex":12},{"imageOffset":500393,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":12},{"imageOffset":1686204,"symbol":"_NSEventThread","symbolLocation":122,"imageIndex":13},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":11},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}]},{"id":690587,"frames":[{"imageOffset":140705997286008,"imageIndex":8},{"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":9},{"imageOffset":62769,"symbol":"nanosleep","symbolLocation":199,"imageIndex":10},{"imageOffset":1895527,"imageIndex":7},{"imageOffset":344981,"imageIndex":7},{"imageOffset":1739344,"imageIndex":7},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":11},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":1000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703578664508},"tmp1":{"value":140705997285964},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":280615265991945466},"r9":{"value":1000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13051890976},"rsi":{"value":0}}},{"id":690588,"frames":[{"imageOffset":140705997286008,"imageIndex":8},{"imageOffset":16250,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":9},{"imageOffset":26355,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":11},{"imageOffset":1738555,"imageIndex":7},{"imageOffset":356569,"imageIndex":7},{"imageOffset":345450,"imageIndex":7},{"imageOffset":1739344,"imageIndex":7},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":11},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703578664816},"tmp1":{"value":140705997285964},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703578923453,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13052952576},"rsi":{"value":0}}},{"id":690589,"frames":[{"imageOffset":140705997286008,"imageIndex":8},{"imageOffset":5070,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":9},{"imageOffset":64648,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":9},{"imageOffset":34064,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":9},{"imageOffset":5821,"symbol":"mach_msg","symbolLocation":19,"imageIndex":9},{"imageOffset":204370,"symbol":"XServerMachPort::ReceiveMessage(int&, void*, int&)","symbolLocation":98,"imageIndex":14},{"imageOffset":268474,"symbol":"MIDIProcess::MIDIInPortThread::Run()","symbolLocation":104,"imageIndex":14},{"imageOffset":257750,"symbol":"CADeprecated::XThread::RunHelper(void*)","symbolLocation":10,"imageIndex":14},{"imageOffset":264451,"symbol":"CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*)","symbolLocation":77,"imageIndex":14},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":11},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":305677117423616},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703578713224},"tmp1":{"value":140705997286248},"tmp0":{"value":18446744073709551615}},"rbx":{"value":305677117423616},"r8":{"value":0},"r15":{"value":305677117423616},"r10":{"value":305677117423616},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":305677117423616},"r13":{"value":17179869186},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":100},"rcx":{"value":17179869186},"r14":{"value":100},"rsi":{"value":100}}},{"id":690596,"frames":[{"imageOffset":140705997286008,"imageIndex":8},{"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":9},{"imageOffset":62769,"symbol":"nanosleep","symbolLocation":199,"imageIndex":10},{"imageOffset":1895527,"imageIndex":7},{"imageOffset":1023501,"imageIndex":7},{"imageOffset":1739344,"imageIndex":7},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":11},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":1000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703578664508},"tmp1":{"value":140705997285964},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":285383396950043898},"r9":{"value":1000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13054549584},"rsi":{"value":13054549600}}},{"id":690603,"frames":[{"imageOffset":140705997286008,"imageIndex":8},{"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":9},{"imageOffset":62769,"symbol":"nanosleep","symbolLocation":199,"imageIndex":10},{"imageOffset":1895527,"imageIndex":7},{"imageOffset":1023501,"imageIndex":7},{"imageOffset":1739344,"imageIndex":7},{"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":11},{"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":10000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703578664508},"tmp1":{"value":140705997285964},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":248425203367963898},"r9":{"value":10000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13056716368},"rsi":{"value":13056716384}}},{"id":690737,"frames":[{"imageOffset":141644,"imageIndex":5}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13058412544},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13058949120},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":86279},"r14":{"value":0},"rsi":{"value":0}}},{"id":691257,"frames":[{"imageOffset":141644,"imageIndex":5}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13048696832},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":515},"rax":{"value":13049233408},"rsp":{"value":278532},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":0},"rsi":{"value":0}}}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 8639590400,
"size" : 593920,
"name" : "dyld"
"source" : "P",
"arch" : "x86_64",
"base" : 4683563008,
"size" : 36864,
"source" : "P",
"arch" : "x86_64",
"base" : 4683788288,
"size" : 16384,
"source" : "P",
"arch" : "x86_64",
"base" : 4492460032,
"size" : 180224,
"uuid" : "551047f4-3f3d-3722-b296-aed4f64c1b3e",
"source" : "P",
"arch" : "x86_64",
"base" : 4492111872,
"size" : 53248,
"source" : "P",
"arch" : "arm64",
"base" : 140703125921792,
"size" : 196608,
"name" : "runtime"
"source" : "P",
"arch" : "arm64",
"base" : 4483313664,
"size" : 344064,
"source" : "P",
"arch" : "x86_64",
"base" : 4339924992,
"size" : 2899968,
"uuid" : "81e0d438-83c0-389d-9fd7-94215e83b8c3",
"size" : 0,
"source" : "A",
"base" : 0,
"source" : "P",
"arch" : "x86_64",
"base" : 140703578648576,
"size" : 241656,
"source" : "P",
"arch" : "x86_64",
"base" : 140703577497600,
"size" : 557048,
"source" : "P",
"arch" : "x86_64",
"base" : 140703578890240,
"size" : 49144,
"source" : "P",
"arch" : "x86_64",
"base" : 140703579312128,
"size" : 4825085,
"source" : "P",
"arch" : "x86_64",
"base" : 140703635955712,
"size" : 21159926,
"name" : "AppKit",
"source" : "P",
"arch" : "x86_64",
"base" : 140704038555648,
"size" : 573430,
"sharedCache" : {
"base" : 140703574474752,
"vmSummary" : "ReadOnly portion of Libraries: Total=828.9M resident=0K(0%) swapped_out_or_unallocated=828.9M(100%)\nWritable regions: Total=2.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.1G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nActivity Tracing 256K 1 \nCG image 51.6M 468 \nColorSync 244K 30 \nCoreAnimation 13.8M 88 \nCoreGraphics 12K 2 \nCoreUI image data 2288K 19 \nFoundation 40K 2 \nKernel Alloc Once 8K 1 \nMALLOC 1.9G 91 \nMALLOC guard page 192K 12 \nRosetta Arena 4096K 2 \nRosetta Generic 1320K 327 \nRosetta IndirectBranch 1024K 1 \nRosetta JIT 128.0M 1 \nRosetta Return Stack 220K 22 \nRosetta Thread Context 220K 22 \nSTACK GUARD 16K 4 \nStack 16.1M 12 \nStack Guard 56.0M 8 \nVM_ALLOCATE 19.6M 55 \nVM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)\n__CTF 824 1 \n__DATA 33.8M 555 \n__DATA_CONST 37.3M 355 \n__DATA_DIRTY 1597K 201 \n__FONT_DATA 2352 1 \n__LINKEDIT 176.4M 12 \n__OBJC_RO 71.7M 1 \n__OBJC_RW 2193K 2 \n__TEXT 652.5M 577 \ndyld private memory 260K 2 \nmapped file 194.6M 44 \nshared memory 1340K 20 \n=========== ======= ======= \nTOTAL 3.3G 2941 \nTOTAL, minus reserved VM space 3.3G 2941 \n",
"legacyInfo" : {
"logWritingSignature" : "5dc51ee31fad8f98bb0bb6bc2ba247d3d11249ca",
"trialInfo" : {
"rollouts" : [
"factorPackIds" : {
"factorPackIds" : {
"experiments" : [
"reportNotes" : [
"PC register does not match crashing frame (0x0 vs 0x102C66C7B)"
AirPort:
USB Device: D512S
Noted.
So please do this:
- post a link to donwload a ZIP file of your lightshow (https://forum.thelightingcontroller.com ... ?f=3&t=168)
- tell us what model of DMX interface you have
- if possible, tell us the fastest way to reproduce the crash
Then we will run the same setup (M1 & software & DMX interface) than yours, until we get the crash.
PS : the Apple crash report is not very helpful for us.
ChaseThe28
support wrote:Noted.
So please do this:
OK, thanks.
- Link to the lightshow is here:
https://drive.google.com/drive/folders/ ... sp=sharing
- I'm using a Chauvet DJ Xpress 512S
It's a bit random for crashing but I seem to be mainly in the Steps screen when it happens but this might be because that's where I have been working the most. It seems to go most when I'm moving a fader but that could just be coincidence and I haven't been able to find a way to reliably replicate the issue.
Cheers
Mark
ChaseThe28
Generally speaking though, it does seem to crash a chunk less often after the fix and, luckily, hasn't crashed at all during Live.
Good news !
We made some code change related to that problem since V9.3.8, so this makes sense.
Return to “Mac OS”
