Shehds - 275w 10R Moving Head Light
Hi, could you please create a profile for the Shehds Beam 275W 10R moving head light? 16 channels. SSL2 and R20 files provided by the manufacturer. Dropbox link: https://www.dropbox.com/sh/zem9jo6z4hjr ... iezDa?dl=0
Thank you
Thank you
Re: Shehds - 275w 10R Moving Head Light
Thank you. Where would I download? I've looked at http://download.thelightingcontroller.c ... or_Editor/
Sorry, our mistake.
Should be ok now.
Please try again.
Should be ok now.
Please try again.
Good to go, thank you very much!
I've expanded on the 10r light to include the individual colors, gobos, FX and settings that are not included in the manual for each output. Thank you guys again, it works great. BTW, little note about this spot - I've found you have to start it, and go to Program-->change to "Sound" and then back to "Auto" before it works. Just in case anyone out there uses this.
- Shehds_275W10R_v2.txt
- (1.71 KiB) Downloaded 1257 times
musicmaker
Can you provide the profile file with Martin Light Jockey extension, *udf or udo.
Thank you!
Thank you!
Sorry we provide fixtures profiles exclusively for our software.
musicmaker
I use both your and Martin, and I need in Martin file extension too. Is there a converter or something like this? Thank you.
