Mapper Akai APC Mini 2 [fixed]
jijo71
Post by jijo71 »
BONJOUR ATOUS JAIMERAI SAVOIR COMMENT MAPPER UN OU PLUSIEURS AKAI APC MINI 2 MERCI DE VOS REPONSES
Re: MAPPER AKAI APC MINI 2
Voici un tuto pour ça : https://www.youtube.com/watch?v=7bykEKgb260&t=1s
jijo71
Re: Mapper Akai APC Mini 2
Post by jijo71 »
bonjour merci pour l'info bonne journée
Tarzan4711
Post by Tarzan4711 »
I am testing the new APC mini mk2 board. The colors of the keys shine only very weakly. Is there a solution for the mini mk2 board?
We do not have this device, so we can not test quickly. Sorry for that.
However, in our software, it is possible set any value for the "midi out" message.
We suggest you to check which values are the best for the midi device in its manual.
Tarzan4711
thank you for the feedback. I think the "new" APC mini mk2 is no longer compatible with the software because of the RGB colors. With the "old" APC mini everything works fine.
