Chauvet - ColorDash Batten Tri
The manual is wrong on this fixture and therefore so is the profile, specifically the last channel. If you want, I can upload mine but let me know where to send it.
Re: Chauvet - ColorDash Batten Tri
Where did you find a profile for the Batten Tri?
I don't understand why correct profiles are not ALWAYS provided (nor readily locatable via advanced Internet searches) by Chauvet, at least on PRO fixtures as this? I know it's of some importance because being brand-spanking-new to DMX lighting, I wasted a lot of time troubleshooting down the wrong path because I relied upon an incorrect manual and/or wrong Chauvet-provided profile.
Brand newbie + 15 fixtures via home delivery + 3 wrong manuals/profiles = more than a few wasted hours.
Why not have every profile linked for download under the "Resources" tab of each product page? If you need it & on the road w/ limited access & mental resolve, you'd know it would always be there. Does everyone usually write their own, swap by mail, or something else I've neglected to comprehend as a beginner? Nonetheless, the process did accelerate the learning curve & hardly classify myself that now.
Signed,
Confused in Canton
Signed,
Confused in Canton
I found it in the software. Honestly, it is not them. Chauvet's manual is wrong.
What exactly is wrong about the manual?
Allan Reiss
Senior Product Manager
CHAUVET DJ
CHAUVET DJ
On 10-channel mode, the blocks are not the same as the manual. The manual does not contain the DMX values for Block 4. I figured them out, though.
Here is what I found them to be for my programmed scenes:
Block 1: 21
Block 2: 41
Block 3: 61
Block 4: 81
Block 1&2: 100
Block 1&3: 120
Block 1&4: 143
Block 2&3: 161
Block 2&4: 180
Block 3&4: 200
I would have to fire them up to give you the exact DMX ranges.
Block 1: 21
Block 2: 41
Block 3: 61
Block 4: 81
Block 1&2: 100
Block 1&3: 120
Block 1&4: 143
Block 2&3: 161
Block 2&4: 180
Block 3&4: 200
Kahilzinger,
I checked the fixture and you are correct. The manual will need to be modified. Here are the correct values:
Channel 10 - Block
000-019=Block 1,2,3,4
020-039=Block 1
040-059=Block 2
060-079=Block 3
080-099=Block 4
100-119=Block 1,2
120-139=Block 1,3
140-159=Block 1,4
150-179=Block 2,3
180-199=Block 2,4
200-219=Block 3,4
220-239=No Function
240-255=Full on
Thanks for catching this! I will have the manual and SX profile updated once everyone returns from the InfoComm show.
Thanks for your support!
Channel 10 - Block
020-039=Block 1
040-059=Block 2
060-079=Block 3
080-099=Block 4
100-119=Block 1,2
120-139=Block 1,3
140-159=Block 1,4
150-179=Block 2,3
180-199=Block 2,4
200-219=Block 3,4
220-239=No Function
240-255=Full on
Allan Reiss
CHAUVET DJ
CHAUVET DJ
