D-Fi with ShowXpress
post here other topics
Route66Ride
Post by Route66Ride »
Newbie question: I have a couple of PARs that I normally wire DMX to an Xpress 512S. Someone gave me two D-Fi USBs, but how do I control them with ShowXpress on my Windows laptop? Do I need other equipment, or am I not configuring ShowXpress correctly?
Thank you!
Re: D-Fi with ShowXpress
"D-Fi USBs" is for another kind of lighting controller.
Our software is not compatible with.
Robin_D
Post by Robin_D »
You need the D-Fi XLR transceiver or hub. That connects from the dmx line and will then connect to the USB devices you have. Note that the lamp must have a USB port. If you only have the XLR at the lamp end , you need the D-Fi XLR device.
Plugging them into the laptop doesn't help as it's the DD MX Express that creates the DMX signal I believe, not the software in the laptop.
Return to “Other”
