[6.00] can not select the corret lamp power [fixed]
Posted: 07 January 2010, 16:42
by jtorrence
I am unable to select the correct lamp strength in 6.0. I have Intimidator 2.0 lights. they have a 250W bulb. However, when I attempt to select that in the fixture setup and click save, it defaults to 30W bulb. I am unable to change it back. This causes the beam distance not to be accurate in 3D. I have the same problem with LEDSplash JR and ColorDash Batten.
Re: [6.00] can not select the corret lamp power [fixed]
Posted: 09 January 2010, 10:56
It is a bug.
It is fixed.
The fix is available in the fixed files.
Posted: 09 January 2010, 19:02
by jtorrence
Which version of fixed files ? I version posted as late as 1/7/10? With those files when I click SAVE on Intimidator2.0 using 250W lamp it defaults to 30W.
Posted: 20 January 2010, 23:33
by fedo
excusez moi mais je ne comprends ce qu'est le fix file quand je télécharge le fichier et que je le dézippe, je tombe sur un fichier read me ?? que dois je en faire ??
voilà ce qui est écrit dans le read me files
When existing, copy the new language files into "ControlBoard/language/", or "Setup/language/", or "Editor/language/", or "Live/language/", or "3DView/language/".
où sont les fichiers à copier ?
merci
Posted: 21 January 2010, 08:07
On vient de mettre à disposition la version 6.01 qui contient la version 6.00 avec les fix.
Une fois que la version 6.01 est installée, il n'y a plus de fix nécessaire.
Le fichier fix est par conséquent vide.
