[6.00] can not select the corret lamp power [fixed]
jtorrence
Post by jtorrence »
I am unable to select the correct lamp strength in 6.0. I have Intimidator 2.0 lights. they have a 250W bulb. However, when I attempt to select that in the fixture setup and click save, it defaults to 30W bulb. I am unable to change it back. This causes the beam distance not to be accurate in 3D. I have the same problem with LEDSplash JR and ColorDash Batten.
Re: [6.00] can not select the corret lamp power [fixed]
It is a bug.
It is fixed.
The fix is available in the fixed files.
jtorrence
Post by jtorrence »
Which version of fixed files ? I version posted as late as 1/7/10? With those files when I click SAVE on Intimidator2.0 using 250W lamp it defaults to 30W.
fedo
Post by fedo »
excusez moi mais je ne comprends ce qu'est le fix file quand je télécharge le fichier et que je le dézippe, je tombe sur un fichier read me ?? que dois je en faire ??
voilà ce qui est écrit dans le read me files
When existing, copy the new language files into "ControlBoard/language/", or "Setup/language/", or "Editor/language/", or "Live/language/", or "3DView/language/".
où sont les fichiers à copier ?
merci
On vient de mettre à disposition la version 6.01 qui contient la version 6.00 avec les fix.
Une fois que la version 6.01 est installée, il n'y a plus de fix nécessaire.
Le fichier fix est par conséquent vide.
Return to “Setup”
