request - Multiple MIDI Trigger Output
Bobnjul
Post by Bobnjul »
Something that would be useful to me is the ability to trigger multiple MIDI commands from one Live Mode Button. I can find usefulness in having both the option for it trigger two or more MIDI commands simultaneously OR in succession from within the Button Trigger dialog. (I use Show Express to trigger projection screen images via MIDI - being able to send two messages from one button push would make my programming so much more efficient.)
I would also love to see the ability to implement MIDI from within the Step Editor... but I'll setup a new thread over there.
Re: Multiple MIDI Trigger Output - Request
Read.
dumbfungus
Re: request - Multiple MIDI Trigger Output
Post by dumbfungus »
Hey here’s a work around you can use maybe. Tell me if it wouldn’t work. Each button has midi in as well as midi out. Make use of that.
Make a blank scene and button. Set it up as a flash button in software. Set midi Trigger it with whatever button you’re already using for the button you already had. So Basically your physical midi button will Now activate 2 showXpress buttons.
So now assign midi output of the new blank Button. You have 2 buttons active, so you’d have 2 buttons sending midi out message.
Make a 3rd or 4th if you want. Just be sure to assign midi output like you want. Activate them all with the same midi trigger
Or you can use a macro to trigger multiple buttons ...
Bobnjul
Post by Bobnjul »
Hey guys, I'll try these solutions and see how it goes.
