Good day.
I have added a new LED-pixel-chain to my Sweetlight and control it by pixel. But with a strange phenomenon.
To the facts:
There is a long pixelstripe in Universe 2, this has 120 pixels with 3 channels for RGB, i.e. DMX address 001-360. I have now added the new LED-pixel-chain at the back, this has 50 pixels with 3 channels for RGB, i.e. DMX address 361-510.
Now I have programmed a rainbow in pixels for the new LED-pixel-chain, which works perfectly with red / black and with green / black as seen in the video. But if I change the color to blue or any shade of blue, for some reason the long LED stripe on DMX channels 001-360 comes on briefly in completely red.
I have checked everything for many hours now and find no error in my settings. Universe 1 with all devices does not seem to be affected.
Does anyone have an idea where to start searching for errors?
Here is the short video showing the problem: https://druckluftkammer.de/stuff/sweetlight.mp4
						Interaction between 2 fixtures [fixed]
Re: Problems within pixels
Long strip DMX 1-360
Shorter st. DMX 361-510
I have a feeling your channels are overlapping somewhere. From the looks of it, not in Sweetlight. All though we have not seen mapping addresses.
Thore
Using HW: D1024 & D512
Controller: 2x Akai APC mini
my DIY light mixer
my DIY light mixer
Do you mean that with mapping adresses?
The short LED-pixel-Chain is controlled by 2811 chips each LED and behind a controller (https://shop.led-studien.de/de/search?p ... words=lk71). The DMX-adress of that controller is set to 361 and to 50 pixels.
Both, the long stripe and the pixel-chain (short stripe) are doing everything fine with normal steps-scenes yet.
[image]
[image]
No, those are the fixture addresses.
Pixel addresses are located here:
Since my pixel bars are 40x1 pixels, the addresses are corrupted on this display, but I guess you understand where to look (Right click > Fixture properties).
But like I said, I don't think the problem is with Sweetlight configuration, but on the physical controller. The addressing there
Thore
my DIY light mixer
my DIY light mixer
I will take a photo tomorrow. Thank you for today.
Ok, I found the problem.
Controller 1 for the long stripe has DMX adress 1 and uses in Sweetlight 001-360 for the 120 pixels
Controller 2 for the short stripe has DMX adress 361 and uses in Sweetlight 361-510 for the 50 pixels
But the channels 510, 511 and 512 are used by controller 1 to make the long stripe full lighten up in red (510), green (511) and blue (512).
So, the channel 510 was double used in my system by the long stripe controller 1 and the short stripe controller 2. I have to say, that I have no idea why controller 1 has these 3 channels always in use.
Thanks for your time.
Good news indeed. Glad you figured it out. Happy lighting
Thore
my DIY light mixer
my DIY light mixer
