Steps working in Editor mode but not in Live mode [fixed]
harveycody@gmail.com
Post by harveycody@gmail.com »
I'm using Showxpress 512 with a Windows 10 computer. I recently installed V9.2.3 and the V9 drivers. All Windows updates have been installed.
Everything is working fine when I'm in "Editor" mode but when I click on the "Live" button, I can only change scenes. It is no longer automatically starting and running the steps.
An suggestions how I might fix this?
Re: Steps working in Editor mode but not in Live mode
Usually, the reason of this problem is: https://forum.thelightingcontroller.com ... =72&t=3614
Is this a problem that was introduced by V8.2.28? I upgraded to V8.2.28 because my light show that has been working great for years quit working a few months ago. I assumed that a Windows update had created an incompatibility.
The upgrade enabled me to get the program to communicate with the lights, but caused the problem I described in the first post in this thread.
Since I wrote that post, things have gotten worse. Now, none of the lights respond to pushing the buttons in Live, but the Editor still works fine.
Please post a video showing the problem.
Here is a link to the video you requested. https://drive.google.com/open?id=1Puh_1 ... kKYySYt7UH
BTW: Thanks much for your prompt responses.
Bob_be
Post by Bob_be »
You will need to turn off the DMX in Editor (small icon in the upper right screen) to test in Live. Editor will override Live...meaning if you have channels active in Editor, the same channels will not respond in Live...unless DMX is turned off.
Gilles
Post by Gilles »
C'est pour cela que j'avais demandé une option ici https://thelightingcontroller.com/viewt ... =75&t=5984
ça serait plus pratique ;)
Re: Steps working in Editor mode but not in Live mode [fixed
Ce n'est pas forcément mieux d'automatiser ce genre de chose.
C'est quand même mieux si l'utilisateur arrive à comprendre, que forcément il y a un écran doit être prioritaire sur l'autre.
Gilles
Post by Gilles »
Je suis d'accord pour que ça ne soit pas automatique et que la manip soit comprise, mais laisser le choix dans une option.
Luc Henrion
Post by Luc Henrion »
oserais-je plussoier ? :lol:
