3x Net 512 interface with Artnet [fixed]
Ethernet to dmx - web server - 9 buttons - calendar
autogedrocht
Post by autogedrocht »
Hello Sweetlight,
I keep having problems with using multiple Net512 with DMX and Artnet.
As far as i know, 1 x Net 512 interface supports 512 DMX channels & 512 Artnet channels.
So with 3 interfaces i should have 1536 DMX channels 1536 Artnet channels (devided on 6 universes)
But how I set this up in the software? I have given every Net512 a static ip. (192.168.1.35 / 192.168.1.45 / 192.168.1.55).
When i turn on 1 interface, sweetlight recognizes 2 interfaces, when i turn on 3 interfaces, it recognizes 6 interfaces.
- But how do i know which universe is which output? I see no numbers.
- When i have these settings, Arnet works, but DMX aint.
What am i doing wrong?
Re: 3x Net 512 interface with Artnet
If we right understand, you have 3 interfaces Net512, and the software sees 6 interfaces !
Could you please connect each interface one by one (the others must be not connected), and tell us the MAC address of each interface ?
Alternatively, you can PM us the serial numbers and we will find the MAC addresses.
autogedrocht
That is correct. I thought that was normal?
I thought that 1 DMX output is 1 interface and the Artnet output is the other interface? But apparently not?
I shall provide the MAC adresses a.s.a.p., I might have changed them in the Net512 software, is that a problem?
This is not normal.
The software is supposed to see only 3 interfaces.
We suspect there is a problem of MAC addresses.
autogedrocht
I connected them 1 by 1, this is the result.
Interface 1 (192.168.1.35) has MAC Address: 70-b3-d5-0b-90-09
Interface 2 (192.168.1.45) has MAC Address: 70-b3-d5-0b-00-8A
Interface 3 (192.168.1.55) has MAC Address: 70-b3-d5-0b-00-01
Can you please send us by PM the serial numbers of these interfaces ?
autogedrocht
Yes, i have send them!
Can you please make the test with two interfaces together (total 3 tests), and tell us if the software sees 2 or 4 interfaces ?
Please tell us also if the dmx output is running with all interfaces (sending value = 0 for all dmx channels).
autogedrocht
support wrote:Can you please make the test with two interfaces together (total 3 tests), and tell us if the software sees 2 or 4 interfaces ?
You mean with autodetect only?
Yes, please press "Autodetect interfaces" and tell us how many interfaces are found.
Return to “Net512”
