Request - Duplicate button menu item
muscanto
Post by muscanto »
Support-
Can you add a "Duplicate Button" function to the right click menu on a button?
Re: Request - Duplicate button menu item
Please explain the purpose of that.
muscanto
Post by muscanto »
Often times I will use the same scene 4-5 times with different speed settings, fade in/out..etc. Having a single click option to duplicate a button would be a nice time saving feature for quickly building new shows.
So you do not like the fader option "Speed" ?
muscanto
Post by muscanto »
The speed function is good when you are triggering scenes by hand and have time to adjust the speed setting on a scene in real time.
When you are triggering from an external source (Midi), you need seperate buttons that are already programmed.
Understood.
Noted, but not a priority because not that much difficult to use the "Add scene" option.
muscanto
Post by muscanto »
Understood- thanks.
