Behringer X-Touch Extender
pattech
Post by pattech »
Does anybody knows or is able to test if I can use a Behringer X-touch extender with sweetlight as a midi-controller ?
pattech
Re: Behringer X-Touch Extender
Post by pattech »
Ok, I bought the extender and it is working with sweetlight.
I have a couple issues with it, maybe somebody can help me with this.
1. the Behringer has automated faders which doesn't work correctly with sweetlight, seems like sweetlight doesn't send the correct values back to the midi-device.
2. the Behringer has scrible strips I would like to use those. With soundsoftware like Studio One the strips are marked directly with the number you put in the slider. But I can't find any way to insert values manually. Does anybody know how to do this ?
regards
In the "midi trigger" section, it is possible to change the midi message which is returned.
pattech
Post by pattech »
support wrote:In the "midi trigger" section, it is possible to change the midi message which is returned.
But when you use the sliders on the right side (patched as dimmer directly to the fixture channels) used as slider in midi. How do you need to set it to send the correct slider-position back to the midi-device ?
In the window: toolbar > "Menu" > "Live settings"
