How to remove a fixture ? [fixed]
seantosz
Post by seantosz »
I added three fixtures to my pixel board and now I cannot delete them. How do you remove fixtures from the pixels map?! no right click option on menu item and keyboard shortcut does not work
Re: How to remove a fixture ?
You can use the lasso to select them.
Then right click over one of the selected fixtures and select "Cut" in the popup menu.
seantosz
Re: How to remove a fixture ? [fixed]
Post by seantosz »
Thank you for your reply. This is what I wound up doing but this method also commits the fixture to the clipboard memory which is unnecessary and a potential pitfall during consecutive workflow.
Noted.
We add in the ToDo list: "add the option 'Delete' in the menu".
Added in the fix file for version V9.1.4 .
Return to “Pixels”
