V9.1.00 - crash with head number management [fixed]
Lighter007
Post by Lighter007 »
the following Bug created a crash in v9, corrupted lightshow attached. To reproduce error do the following steps: add at least two devices of the same type, in my case two moving heads found in the library.
Re open the edit window for device 1, open channel pan, set "head number" to e.g. 1. Close window. Re open the edit window for device 2, open channel pan, set "head number" to e.g. 2. Software crashes, show is corrupted, no entry in error log.
Lighter007
Greetings from Germany! :)
Re: V9 - Bug Report
Thank you for this report.
Fixed in the source code.
We will publish the fix asap.
Re: V9.1.00 - crash with head number management
Fixed and available in the fix file.
Return to “Editor - Fixtures”
