Very Stage - Assassin 2R
markbenthimer
Post by markbenthimer »
ASSASSIN 2r
I just need a profile created to use these in a show next Saturday. Thanks Mark
http://www.verystage.com/ArticleShow.asp?ArticleID=17
Voltage: AC90~240V
Frequency: 50~60Hz
Lamp: 2R 120W Lamp
3° Precision Beam
PRODUCT INFO
Beam,Scanner,Laser Simulator 3 in 1,2R Sniper
● Voltage: AC90~240V
● Frequency: 50~60Hz
● Lamp: 2R 120W Lamp
● 3° Precision Beam
● 3 Facet Rotating Prism
● Color: 14 Dichroic Colors+ White
● Gobo: 17 gobos + open
● X/Y and Z HIGH-SPEED Mirror System
●A four-button control panel and LCD display
●Professional 3 pin DMX in/out ( 5 pin option)
●powercon in/out connections
●An electronice power supply covers worldwide voltages and frequencies
● Control Channel: 15/17/19CH
● Size: 36 x 31x30cm
● Weight: 9.5KG
CH
Function
Instructions
1
0-255
Pan
2
0-255
Pan fine(16Bit)
3
0-255
Tilt
4
0-255
Tilt fine (16Bit)
5
0-7
No function
8-255
Pan Shaking Movement slow to fast
6
0-7
No function
8-255
7
0-2
Open
3-4
Open+color 1
5-6
Color 1
7-9
Color 1+Color 2
10-11
Coloar 2
12-13
Color 2+Color 3
14-15
Color 3
16-18
Color 3+Color 4
59-61
Color 13
62-63
Color13+Color 14
64-65
Color 14
66-67
Color14+Open
68-128
Color wheel index-color1-color 15
129-190
Clockwise color rotation from fast to slow
191-193
Stop
194-255
Clockwise Color Rotation from slow to fast
8
0-7
Open
8-14
Gobo 1
15-22
Gobo 2
23-29
Gobo 3
98-104
Gobo 13
105-112
Gobo 14
113-119
Gobo 15
120-126
Gobo 16
127-133
Gobo 17
134-194
Clockwise Gobo rotation from fast to slow
195-255
Clockwise Gobo rotation from slow to fast
9
0-8
Off
9-16
Pattern Macro 1
17-25
Pattern Macro 2
26-33
Pattern Macro 3
34-42
Pattern Macro 4
43-50
Pattern Macro 5
196-203
Pattern Macro 24
204-212
Pattern Macro 25
221-229
Pattern Macro 26
230-237
Pattern Macro 27
238-246
Pattern Macro 28
247-255
Pattern Macro 29
10
0-9
Stop
10-120
Clockwise pattern Rotation from fast to slow
121-134
Stop
135-245
Clockwise pattern Rotation from slow to fast
246-255
Stop
11
0-9
Stop
10-120
Horizontal pattern Rotation from fast to slow
121-134
Stop
135-245
Horizontal pattern Rotation from slow to fast
246-255
Stop
12
0-127
Pattern Zoom manual
128-255
Pattern Zoom from slow to fast
13
0-127
0-360°
128-191
Clockwise rotation from fast to slow
192-255
Counterclockwise rotation from slow to fast
14
0-7
No function
8-255
Shaking from slow to fast
15
0-255
Prism movement
16
0-127
Prism indexing
128-191
Prism clockwise from fast to slow
192-255
Prism counterclockwise rotation from slow to fast
17
0-255
Dimmer intensity 0-100%
18
0-7
No function
8-255
Strobe from slow to fast
19
0-39
No function
40-59
Lamp on
60-79
Lamp off
80-89
All motor reset
90-99
Pan/tilt motor reset
100-109
Color motor reset
110-119
Gobo motor reset
120-129
Strobe&Dimmer motor reset
130-139
Other motors reset
140-149
Enable blackout when X/Y movement
150-159
Disable blackout when X/Y movement
160-169
enable blackout when color motor move
170-179
Disable blackout when color motor move
180-189
enable blackout when gobo motor move
190-199
Disable blackout when gobo motor move
200-219
System Reset
220-255
No function
markbenthimer
Re: Can someone help with this profile PLEASE
I need a profile.....
ASSASSIN 2r
Voltage: AC90~240V
Frequency: 50~60Hz
Lamp: 2R 120W Lamp
3° Precision Beam
PRODUCT INFO
● 3° Precision Beam
● Weight: 9.5KG
CH
Function
Instructions
1
0-255
Pan
2
0-255
Pan fine(16Bit)
3
0-255
Tilt
4
0-255
Tilt fine (16Bit)
5
0-7
No function
8-255
6
0-7
No function
8-255
7
0-2
Open
3-4
Open+color 1
5-6
Color 1
7-9
Color 1+Color 2
10-11
Coloar 2
12-13
Color 2+Color 3
14-15
Color 3
16-18
Color 3+Color 4
59-61
Color 13
62-63
Color13+Color 14
64-65
Color 14
66-67
Color14+Open
68-128
129-190
191-193
Stop
194-255
8
0-7
Open
8-14
Gobo 1
15-22
Gobo 2
23-29
Gobo 3
98-104
Gobo 13
105-112
Gobo 14
113-119
Gobo 15
120-126
Gobo 16
127-133
Gobo 17
134-194
195-255
9
0-8
Off
9-16
Pattern Macro 1
17-25
Pattern Macro 2
26-33
Pattern Macro 3
34-42
Pattern Macro 4
43-50
Pattern Macro 5
196-203
Pattern Macro 24
204-212
Pattern Macro 25
221-229
Pattern Macro 26
230-237
Pattern Macro 27
238-246
Pattern Macro 28
247-255
Pattern Macro 29
10
0-9
Stop
10-120
121-134
Stop
135-245
246-255
Stop
11
0-9
Stop
10-120
121-134
Stop
135-245
246-255
Stop
12
0-127
Pattern Zoom manual
128-255
13
0-127
0-360°
128-191
192-255
14
0-7
No function
8-255
15
0-255
Prism movement
16
0-127
Prism indexing
128-191
192-255
17
0-255
18
0-7
No function
8-255
19
0-39
No function
40-59
Lamp on
60-79
Lamp off
80-89
All motor reset
90-99
100-109
Color motor reset
110-119
Gobo motor reset
120-129
130-139
Other motors reset
140-149
150-159
160-169
170-179
180-189
190-199
200-219
System Reset
220-255
No function
The search option of their web site gives 0 result with the name "sniper".
Please give the exact link to download the PDF file of this fixture, and we will do the profile for you.
https://forum.thelightingcontroller.com ... f=3&t=2453
markbenthimer
Re: Can someone help with making this profile PLEASE
ASSASSIN 2r
Thank You... I thin this is the correct link. Please let me know if this isnt the information needed. I just need a profile created to use these in a show next Saturday. Thanks Mark
Voltage: AC90~240V
Frequency: 50~60Hz
Lamp: 2R 120W Lamp
3° Precision Beam
PRODUCT INFO
● 3° Precision Beam
● Weight: 9.5KG
CH
Function
Instructions
1
0-255
Pan
2
0-255
Pan fine(16Bit)
3
0-255
Tilt
4
0-255
Tilt fine (16Bit)
5
0-7
No function
8-255
6
0-7
No function
8-255
7
0-2
Open
3-4
Open+color 1
5-6
Color 1
7-9
Color 1+Color 2
10-11
Coloar 2
12-13
Color 2+Color 3
14-15
Color 3
16-18
Color 3+Color 4
59-61
Color 13
62-63
Color13+Color 14
64-65
Color 14
66-67
Color14+Open
68-128
129-190
191-193
Stop
194-255
8
0-7
Open
8-14
Gobo 1
15-22
Gobo 2
23-29
Gobo 3
98-104
Gobo 13
105-112
Gobo 14
113-119
Gobo 15
120-126
Gobo 16
127-133
Gobo 17
134-194
195-255
9
0-8
Off
9-16
Pattern Macro 1
17-25
Pattern Macro 2
26-33
Pattern Macro 3
34-42
Pattern Macro 4
43-50
Pattern Macro 5
196-203
Pattern Macro 24
204-212
Pattern Macro 25
221-229
Pattern Macro 26
230-237
Pattern Macro 27
238-246
Pattern Macro 28
247-255
Pattern Macro 29
10
0-9
Stop
10-120
121-134
Stop
135-245
246-255
Stop
11
0-9
Stop
10-120
121-134
Stop
135-245
246-255
Stop
12
0-127
Pattern Zoom manual
128-255
13
0-127
0-360°
128-191
192-255
14
0-7
No function
8-255
15
0-255
Prism movement
16
0-127
Prism indexing
128-191
192-255
17
0-255
18
0-7
No function
8-255
19
0-39
No function
40-59
Lamp on
60-79
Lamp off
80-89
All motor reset
90-99
100-109
Color motor reset
110-119
Gobo motor reset
120-129
130-139
Other motors reset
140-149
150-159
160-169
170-179
180-189
190-199
200-219
System Reset
220-255
No function
markbenthimer
Hello, I received this from one of the members on here.... Im still hoping someone can help me with this profile. I want to start writing scenes....
Hey mate, just saw your request on the forum. The manual you've provided doesn't specify which colour or gobo, as you've said. It just lists "colour 1, colour 2" etc. That means when you get the finished profile, it won't appear as desired in 3D view. It will still function properly in real life though obviously. If you really want the colours and gobos to appear properly in 3d view you'll have to provide a better manual or some sort of other reference for which colours and gobos are which
My reply.....Yes...thats all they have. I figured I could edit in that information on the profile later....as I use the lights. Am I correct. Or .... I was told it matches the color and gobo selection of the elation 2r sniper......and the profile for that light is in the Showxpress library. Ive also been told it matches the Art Fox Beam 2R but I couldnt locate that profile
Done.
markbenthimer
Re: Very Stage - Assassin 2R
Where do I find it ?
