Freedom sticks 50 Channel keeps strobing [fixed]
djmamasboy
Post by djmamasboy »
I am using Chauvet Freedom sticks dmx 50 channel. I want to Pixel map them in show express. When I use any of the effects (Rainbow, Chaser) all the LEDs strobe. The effect is working but it is also flashing the whole time. When I import the 48 channel profile it works just fine. Any help would be great! Thanks!
Re: Freedom sticks 50 Channel keeps strobing
We double-checked the profile and we saw that the channel 49 is forced to 255.
This is the reason of the constant strobe.
Please do this:
- edit the profile (in Pixels, right click over the fixture and select "Fixture Properties")
- edit the shared channels (click on the button "Edit" in the section "Shared channels")
- click on the check mark "Disable" for the first channel (at the left) (this is channel 49), or put its slider at level 0
In one case you do not override it, in the other case you force it at level 0.
Return to “Pixels”
