Conventional "fixtures" (parcan not RGB) [fixed]
dorian
Post by dorian »
I was wondering the simple way to create a fixture with a single channel, but with a gel that I could preview in 3D. I'm using conventional lights and LED on the same rig. Thank you and sorry to ask, I could not find the answer on my own
Re: Conventional "fixtures"
Create a one channel (called "dimmer") fixture, and set the following 3D parameters:
- select "parcan old (not RGB)" in the combobox
- press the button "Beam color" and select the color of the gel in the "color setting" window
dorian
Re: Conventional "fixtures" (parcan not RGB) [fixed]
Post by dorian »
wow, that was fast and so efficient, works perfectly now...and thank you very much.
Lets create now :)
Return to “Editor - Fixtures”
