[Request] Add more fixtures to existing generator file
SeekLighting
Post by SeekLighting »
Hi Support,
At the moment, when you have created a project in generator, if you attempt to select another fixture to add to the file, the software forces you to start from scratch. It would be great if there was a way for you to add a fixture to a scene quickly and simply update it.
For example, let's say I have a generator project with 4 moving heads. I then wanted to add a new fixture to the show and add the 5th fixture into the same generator project. It would be great if this were possible in future releases!
Regards,
Tim H
Re: [Request] Add more fixtures to existing generator file
Noted but not easy.
Please note that you can save the curves.
It is not so flexible than what you are asking for, but it helps.
SeekLighting
Thanks for the reply. I understand it would be tricky, but thanks for listening to the suggestion. It would make a lot of users very happy! :D
samwise309
Post by samwise309 »
+1 for this :D
