I am currently trying to write code for a 48 channel DMX controlled dimmerusing a PIC24FJ32GA002(datasheet:http://www.kynix.com/uploadfiles/pdf879 ... -E2fML.pdf). Using a scope I have confirmed that there is a DMX signal reaching the Rx pin of the UART which has been configured correctly using the PPS function of the pic. Also nested interrupts are disabled.
Below is the contents of my ISR for the UART Rx interrupt. What happens when I debug it with a breakpoint set inside the ISR is that the ISR triggers once or twice with null data reaching U1RXREG, it then fails to trigger again and the program runs with no further interrupts.
The main loop for the program has a loop that processes the incoming DMX packets and outputs to the PWM controller. dmxRecieveByte() takes the contents of rxbyte and places it into a buffer that's the right size to store a DMX packet (512 bytes) to then be copied to a separate buffer when the packet is received.
UPDATE: I have changed the ISRs so that there are seperate handlers for errors and incoming bytes, the uartRecieve() function now handles sorting the incoming bytes and the ISRs take care of clearing flags and such. The Tx ISR is there as a placeholder untill I get the DMX functionality working correctly.
UPDATE 2: Added the UART init code and the updated Rx ISR code, still getting the ISR firing once at the programs first run then not happening again. I've got the production hardware now so any variables that were in that have been removed. Poked around with a scope probe and everything seems to be in order signal wise.
UART Init function
void dmxInit(void)
DMX_UART_MODE = 0b0000000000001001;
DMX_UART_BAUD = (FCY/(4*250000))-1;
DMX_INT_PRIORITY = 0x07;
PORTBbits.DMX_RX_MUX = 0;
spareBufValid = 0;
DMX_UART_ENABLE_BIT = 1;
DMX_INT_ENABLE_BIT = 1;
UART Rx ISR
void __attribute__ ((interrupt,no_auto_psv)) DMX_INTERRUPT_FUNC(void)
uint8_t dmxData;
if(DMX_OVERRUN_BIT)
{ // Overrun error
DMX_OVERRUN_BIT = 0;
dmxReset();
else
{ // empty any data in the UART fifo
while(DMX_DATA_AVAIL_BIT)
if(DMX_FRAME_ERR_BIT)
{ // frame error
if(DMX_DATA_REG)
{ // data is not 0 - not a break
dmxReset();
else
{ // its a break!
breakDetected = 1;
startDetected = 0;
if(writeCount)
dmxWriteBufSwap();
else
{ // data in the fifo
dmxData = DMX_DATA_REG;
if(breakDetected)
if(startDetected)
{ // some DMX data
if(rxCount == fixture.DMXStartAddress)
pByteWrite = pWriteBuf;
if(pByteWrite)
*pByteWrite++ = dmxData;
writeBufSize++;
if( (writeBufSize >= NumberOfChannels) || (rxCount >= NUM_DMX_CHANNELS-1) )
{ // finished receiving this packet
dmxWriteBufSwap();
rxCount++;
else
{ // This is the start code
if(dmxData == DMX_DATA_START_CODE)
startDetected = 1;
writeBufSize = 0;
rxCount = 0;
else
{ // some other start code
dmxReset();
DMX_INT_FLAG_BIT = 0; // Clear interrupt flag
Write code for a 48 channel DMX controlled dimmer using a PI
post here other topics
Jump to
- General
- ↳ Announcement
- ↳ Annonces
- ↳ Anzeige
- ↳ Deutsches Forum
- ↳ FAQ's
- ↳ Download
- ↳ Tutorials
- Software
- ↳ Editor - Fixtures
- ↳ Editor - Steps
- ↳ Editor - Generator
- ↳ Editor - 2DView
- ↳ Pixels
- ↳ Live - Buttons
- ↳ Live - TimeLine
- ↳ Live - Sequential List
- ↳ StandAlone
- ↳ 3DView
- ↳ General software
- ↳ First version Alpha
- ↳ Midi
- ↳ Artnet
- ↳ Virtual DJ
- ↳ Version 6
- ↳ ControlBoard
- ↳ Setup
- ↳ Editor
- ↳ Pixels
- ↳ Live
- ↳ Buttons
- ↳ TimeLine
- ↳ General
- ↳ beta versions
- ↳ 6.20 beta
- ↳ 6.21 beta
- ↳ 6.22 beta
- ↳ 6.23 beta
- ↳ 6.24 beta
- ↳ 6.25 beta
- ↳ 6.26 beta
- ↳ 6.27 beta
- ↳ 6.30 beta
- ↳ beta files [closed]
- ↳ 6.33 beta
- ↳ video training
- Remote Control with "Live Mobile"
- ↳ General
- ↳ iOS (iPhone, iPad)
- ↳ Android
- ↳ Web browser
- Operating System
- ↳ Windows
- ↳ Mac OS
- DMX interfaces
- ↳ D512S
- ↳ D1024
- ↳ Rack1024
- ↳ Net512
- ↳ Cable
- ↳ D512
- ↳ Remote
- ↳ Rack
- ↳ Box
- ↳ Ssa
- ↳ General hardware
- Miscellaneous
- ↳ Tutorial videos from users
- ↳ 3DView shows from users
- ↳ Gigs from users
- ↳ Screenshots from users
- ↳ Feedback from users
- ↳ Fixture profile requirement for Editor
- ↳ Fixture profile requirement for Pixels
- ↳ Other
- ↳ Repetitive questions
- ↳ Trash
