Crash when using a Midi command to pause a timeline [fixed]
spielberger
Post by spielberger »
Dear Support,
I'm working on a music show using timelines for audio and light. The show is not yet completed but I tried to run the already finished timelines by MIDI commands. But there is a serious issue with MIDI which causes the complete software to crash. I don't know if it is because of our slightly new workflow, but I don't think so.
My Workflow
What I basically do is run timelines for a seqeunce of one or two songs. Between the sequences/songs - at the end of a timeline - I manually activate an "intermission"-scene (called MOD_MAIN) on another page to load a new timeline in the background. When the talent starts the next song the next timeline is played and the MOD_MAIN-scene is switched off using single-button-mode on the intermission-page at the same time the timeline starts - this allows a smooth transition. This has worked for 5 shows on all older software versions!
But now we wanted to add more videoscreens so we have to roughly synchronize the start of a timeline with an external videoplayer. Due to different filesizes sweetlight has slightly different loading-times, I simply worked around this by adding a pause at the first second of the timeline and then sending synchronized MIDI Cues to two different systems - one is Sweetlight playing the preloaded audio and light timeline - the other triggers a video on the external player. So I updated to Version 8.2.27 to have the great new feature of controlling the Timeline-PLAY-Button via MIDI. Because my show is completly triggered by a MIDI-command cuelist.
The Bug
With just one timeline it worked fine BUT by switching to the next I encountered a serious bug: When a MIDI device is activated or present, the stopping of a running timeline causes Sweetlight to crash completly. There is no way around it execpt disabling the MIDI devices. I made a video showing the complete problem: https://drive.google.com/open?id=10ZCEK ... Luxnd3Rpcs
I uploaded my show so that I can send it to you if you want to take a look.
System: Windows 10 - 64bit
Version: 8.2.27
Thanks for your help and support!!!
spielberger
Re: BUG - Crash when stopping Timelines while MIDI activated
I forgot to mension one important thing :shock:
IF THERE IS NO MIDI-COMMAND FOR PLAY/PAUSE it doesn't crash! You will see it in the video in at last minute.
Please unzip and install this file in your software folder https://download.thelightingcontroller. ... _Debug.zip
And make again your tests.
You should see more informations regarding the error in a window, when the crash occurs.
Then please post a screenshot of the error message.
spielberger
I attached the error message - couldn't see more than that, because when the software crashes the debug disappers after 1 - 2 seconds.
[image]
Thank you.
Please post a link with a zip of your lightshow (https://forum.thelightingcontroller.com ... ?f=3&t=168).
spielberger
support wrote:Thank you.
Done via mail
Thank you for your clear and precise reports.
Thank to them, we were able to reproduce easily the crash.
It is normally fixed in the "fix" file.
https://forum.thelightingcontroller.com ... =85&t=3438
Please try it, and let us know the result.
spielberger
YES! The fix did the trick! It works now without a problem.
THAT‘S WHAT I CALL SUPPORT! Thanks a lot.
Re: Crash when using a Midi command to pause a timeline [fix
Good news !
Thank you for the feedback.
Return to “Live - TimeLine”
