How to change gobos ? [fixed]
will_notley
Post by will_notley »
can any one help me with a charismas gobo and any other cool gobos.
SeekLighting
Re: gobos
Post by SeekLighting »
Hey mate,
You'll have to be more specific with your question. What exactly are you looking to do? Are you hoping to modify a fixture to change which gobos appear in 3d view?
Regards,
Tim H
will_notley
Re: gobos
yes I am thanks
SeekLighting
Re: gobos
Ok, that's easy.
Step 1) Go to "Fixtures" Mode
Step 2) Right click on the fixture you want to modify and click "Edit Fixture"
Step 3) On the left hand side of the dialog box that appears, click the Gobo Channel
Step 4) On the right hand side, select the channel value of the gobo you wish to modify and double click it
Step 5) On the dialog box that appears, go to the drop down menu in the top left hand corner that says "Miscellaneous". From there, you can select what type of gobo you wish to add (coloured, metal, glass, etc.)
Step 6) Select which gobo you want to add to that channel and double click it
Step 7) Press "Save" on the Edit Fixture Window to save your changes and exit back to fixtures mode
You should then be able to see your new gobo in 3D View :)
Regards,
Tim H
will_notley
Re: gobos
thank you very much
:D :D :D
tjjano33
Re: How to change gobos ? [fixed]
Post by tjjano33 »
I tried to import my own gobos into the C:\Program Files\ShowXpress\3DView\gobos folder, copying the same dimensions as used in the gobos provided with the program, I also created a new sub folder so I can easily spot them. However neither the sub folder nor the gobos are visible in the program, can someone assist?
tjjano33
Post by tjjano33 »
Awesome. Thanks!
jimph
Post by jimph »
Thanks, I was looking for this. I couldn't display the new gobos, it's easy if you know how :D
My zodiac sign is Pisces. From the Pisces compatibility percentage table, I knew that my best match is Cancer! So, I'm looking for a Cancer woman :)
Return to “Editor - Fixtures”
