Random and chase buttom on Live
astronomical clock trigger & dmx output patch
pogjack
Post by pogjack »
Didn't know if this is where you wanted posts of items noted in 6.26 or just software issues but here goes.
Is it possible to set the random and chase buttons to:
1. Not be a solo select. Say I have a LED PAR on blue, I want random or chase to pick another color (or scene) and it fade into it like the button is designed to do and not solo the buttom, makes it black out lights and fade in if the button is set that way.
2. Set Random or chase to manual, automatic BPM or be able to set the number yourself.
3. If I understand correctly, the text size change only changes all text, can I change only one buttons size if needed?
Anyways, I ditto what one of the guys said in a past post, this is by far one of the best softwares available.
Thanks,
Re: Random and chase buttom on Live
Thank you for your comment.
Unfortunately, we do not have answers which could enjoy you.
1. we add in the TODO list "check possibility to avoid "black" when random/chase playing from one scene to the next scene"
2. it is not possible to modify the trigger timing of random/chase play (you can work around by modifying the scene)
3. the buttons text size can only be adjusted for all buttons
"1" is fixed in the fix files here: http://download.TheLightingController.com/software/V6/
Return to “6.26 beta”
