I have created generated moves and to go with that I added scenes with colours however none of the colours are working its locked on white, and white is the only colour I get. The colour wheel now says "select a RGB/CMY fixture" however the moving head is a coloured feature and it wont allow me to use colour wheel.
Thanks guys Brett
No colours for moving heads only white
Re: No colours for moving heads only white
Your moving head isn't a RGB or CMY fixture, it has a colour wheel in it. You can't use the colour picker with a non RGB or CMY fixture.
Go through your scenes and manualy select the colours by sliding the number 6 fader until you have the desired colour.
Thanks guys
