apc mini slider causing crash [fixed]
n3qxc
Post by n3qxc »
WIndows 7 OS (enterprise edition)
APC mini
SE Ver 8.2.10
scene has 39 steps (each step selects a built in Macro for the Chauvet circus 2.0 Irc)
Slider 50 mapped to the scene as a button trigger.
Slider crashes when moved to zero position or moved from zero position too fast. I can move thru the higher steps back and fourth without issue.
Slider 48 also causes a crash. it is mapped to a scene with 10 steps for macro selection on a Chauvet 6 spot.
I have another slider mapped to a scene that has 20 steps (xlaser) and has no crashing issue.
I have another laptop with the same lightshow that doesn't have this issue, but is using an earlier version... 8.1.??
I have 2 apc mini and have swapped them with the same results.
Dongle was not connected at the time of my video I'm about to share. Only Usb devices connected at the time of testing is the APC mini and a mouse.
Here is a link to the video on youtube: https://www.youtube.com/watch?v=rnmltmi ... e=youtu.be
Re: apc mini slider causing crash
This issue is corrected since fix file 8.2.12 (viewtopic.php?f=2&t=4859#p19835)
Please install the latest fix file : viewtopic.php?f=85&t=3438
n3qxc
Post by n3qxc »
Thank you, I will update to the newest version!
