[request] "Lowest Takes Priority" for midi inputs
BartKrap
Post by BartKrap »
Hey Support,
Can it be possible to add master to the priority mode in the fixtures MIDI inputs option? I've started using quite a lot of dimmer curves recently and find myself running out of master faders.
If possible make it so that when there are no shows that use the dimmer they act just like the "Input" and "HTP" priority modes.
Thanks in advance.
Re: Fixtures MIDI inputs Priority mode Master [Feature Reque
The midi input management in tab Editor > Fixtures is able to only patch midi to channels of fixtures. It has nothing to do with the tab Live. It is not possible to manage channels of tab Live, from tab Editor > Fixtures.
Sorry but this is not possible.
BartKrap
Post by BartKrap »
support wrote:The midi input management in tab Editor > Fixtures is able to only patch midi to channels of fixtures. It has nothing to do with the tab Live. It is not possible to manage channels of tab Live, from tab Editor > Fixtures.
Okay I understand, could it be possible to implement a Lowest Takes Priority mode?
This should be possible.
viewtopic.php?f=3&t=4909
lse
Re: [request] "Lowest Takes Priority" for midi inputs
Post by lse »
+1
Return to “Editor - Fixtures”
