My company's primary LED static wash fixture is the ColorDash Par Quad 7. Using the supplied 10CH profile file, the dimmer doesn't work in 3D mode, but it works with the strobe feature acting as the main dimmer. How can this be corrected?
[image]
ColorDash Par Quad 7 - dimmer not working [fixed]
elysiumexp
Nicholas Hardy | Executive Producer
the Elysium Experience | Event Design • Production • Talent
20504 Hall Road • Clinton Township, MI 48038
http://elysiumexp.com
Re: 3D View Dimmers & Strobing
You should put the "strobe_dimmer" as "shutter"
And remove the blackout from the dimmer channel (don't forget to change the starting value to 0).
elysiumexp
That worked. Thank you so much.
