TCP/IP : Listen error !
If you see this message, there are two possibilities to fix the problem:
1 - the network port that ControlBoard (or ScreenControl) is trying to use is already used by another external application.
Open Controlboard -> Settings and change the port #.
2 - a resident antivirus/firewall protection software prevent our software to use the network.
Change the parameter of this resident software, in order to allow our software to use the network.
Please note this:
- in major cases, the problem is #2
- there is no risk to allow our software to use the network, since it uses by default local IP (127.0.0.1), which means internal com (and not external com via internet)
Return to “ControlBoard”
