No way to select the Master Speed fader [fixed]
Bob_be
Post by Bob_be »
Problem can be recreated in Demo Show, sound&light.tml. If you move the "Speed beam" fader to 100% you will see when it moves it much quicker. More noticeable, if you moved the fader to -100%, you will see nothing will light up. There is no option in timeline setting or for individual light scenes to be not controlled by the/a (speed) fader. The "Speed Wash" fader doesn't have any effect on the light scenes...that I could notice.
Thank you,
Bob
Re: Bug - Speed fader controls Timeline scenes
Added in V8.1.33.
It is now possible to select the Master Speed fader in the "Light Event properties".
viewtopic.php?f=2&t=4658
Bob_be
Re: No way to select the Master Speed fader [fixed]
Post by Bob_be »
Outstanding! Thanks for putting that in!
2 cosmetic things I noticed is the label for is the selection box reads "Txt_MasterSpeedFader". And in the selection box the text for None (I assume that is what it is suppose to be) reads "Cbo_MasterSpeedFader~Note". (I'm using a windows machine.) I'm not sure if that's by design or not. Thought I would just mention it.
Thanks Again!!!
Bob
Please confirm the language selected in the software (English ?).
In any case, in order to see the new text matching with the new fix, you have to copy the "language" files.
viewtopic.php?f=85&t=3438
Bob_be
Post by Bob_be »
I missed the language file. I installed it (english) and it looks right.
Thank you,
Bob
Return to “Live - TimeLine”
