[request] - Group Dimmer channels
wookie
Post by wookie »
Hi!
I've seen that in new version (8.x.x) there is possibility to group RGB channels as well as Multi Pan-Tilt within generator. I would like to ask you guys for the same for possibility for dimmer channels.
Currently my venue runs few ADJ Sweeper Beam, which contains 8 led, each one with its own dimmer channel. While using generator for making new chases/scenes, I would like to have the possibility to create effects for dimmer in one channel than in 8. In other words - instead of having 8 dimmer channels I would like to group them and run in style like multi-pan-tilt.
Hope you understand what I have in mind.
Cheers!
Re: [request] - Group Dimmer channels
Please note that "Group RGB" and "Explode multi Pan/Tilt" have different goals.
We guess your requirement is a new function "Explode multi dimmer" (?)
This would allow to adjust a delay between internal dimmer channels, inside each fixture.
Not sure we could do it in a near future (big job), but noted anyway because it makes sense.
wookie
Post by wookie »
Yes exactly what I had in my mind - glad you got the point.
It would be really nice to do that! Hope to see in software that some day! Cheers!
