Automated method to creating a count down
rockinmo816
Post by rockinmo816 »
Is there a way to create a 9-0 countdown using pixels? I have some 5x5 matrix panels RGB and I've done this in the past by manually setting the channels and colors to full to create the number I want. I can do it again but it was very time consuming. I didn't know if there was a way to manually select which pixel was on using Pixels, and then selecting color and intensity. Almost like steps. I know we have the ability to load images and GIF's, but they don't seem to work exactly for what I need. No big deal if not, just trying to utilize this to the best of its potential.
Thank you
-Josh
Re: Automated method to creating a count down
No, there is not "countdown" function in Pixels.
We usually suggest to use animated GIF files for that, but the result will be certainly not good enough because of the small res (5x5).
In our opinion, even by programming each pixel separately, it will be difficult to do that in a so small res.
For the result you want, you have to create a 5x5 pixels animated GIF for example in "Gimp", then you will have the exact same result in Pixels.
But downsizing a bigger animated GIF will never be clean in a so small resolution.
rockinmo816
Thanks, i will try that GIF method. Didn't think of that. Appreciate the tip!
-Josh
Return to “Pixels”
